Question about Intel Computers & Internet
I replaced a 2.6 processer with an 3.0. the
I replaced a 2.6 processer with a 3.0. the computer starts to boot, then says the computer is not workable or has been changed, see soft menu. I have gone to the soft menu, but it will not let me save and exit. The comuter works if I hit f1. Processer is intel, and the mother board is ABIT IC-7. Any help would be appreciated.
5.6
Posted on Apr 20, 2009
When device is getting on device is hanging in windows mobile version screen
If its not booting up correctly you can either clean boot the device or reflash the firmware. Note this will return trh device to its default state and loose any information stored on the device.
Clean Booting the CN50
If the CN50 seems to be locked up, try warm booting and then cold booting the computer. If neither method works, use a clean boot to get the computer up and running for further troubleshooting. When you clean boot, the CN50 only loads files and applications that are absolutely required by the operating system. A clean boot returns the CN50 to an "out of the box" or factory default state, so that you can run diagnostic tests to troubleshoot the normal boot processes:
To clean boot the computer using the mobile computer:
1 Remove the battery pack from the back of the CN50.
2 Reinsert the battery pack and press the Power button.
3 When the CN50 starts the boot process, simultaneously press <and > until the IPL Boot Configuration Menu appears on the screen.
4 Press 2 to select Force Clean Boot and then press 0 to select
Continue with Boot.
The CN50 executes the clean boot. This process takes a few minutes
The clean boot process erases the CN50 memory, including all applications and data files in the object store. To preserve applications through a clean boot, store them in the Flash File Store.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 15, 2012 | Intermec CN50 Handheld Mobile Computer -...
Tip
Significantly Speed up computer boot-up
There are many ways to speed up your boot on your computer. I will show you the best ways that will get you the best possible difference. NOTICE: Some tips will work on XP only. A few will work for vista, but not recommended you try it unless you know what you're doing.
1) Process idle tasks
Perhaps the most significant way to speed up your boot and overall computer speed is process idle tasks. On your computer, click start, then run (Or windows key and R), Then paste this command into the box:
rundll32.exe advapi32.dll, ProcessIdleTasks
Let it run, sometimes it takes 10 seconds, other times it takes 10 min. It varies on computer.
2) Disable startup programs
Programs start on boot-up by default, some you may not even want, and it will bog down the computer. Heres how you disable the ones you don't want.
go to the Start -> Run
Type msconfig and press Enter.
Under the Startup tab you will see all the programs that load on boot. If you are unsure what to disable, leave a comment with the question.
3) Disable unnecessary visual effects
Click Start, right click my computer, properties, then advanced tab
Under the section labelled "Performance", click the Settings button to open the Performance Options window. In the "Visual Effects" tab, uncheck everything but the last 3 boxes.
With these 3 major tips, you will see that XP will be much faster and more responsive. For more tips, feel free to drop a comment.
on Dec 29, 2009 | Computers & Internet
Tip
Installation problems for keyboards/mice in XP
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Download the latest version of the software for your OS from the manufacturer's website.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the keyboard/mouse software and remove it. When prompted to remove the keyboard/mouse drivers files, click Yes.
The following is the procedure for a 'clean boot' in Windows XP:
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hopefully, you should not have any problem now.
on Apr 25, 2008 | Logitech LX7 Cordless Optical Mouse
Black screen on start up with blinking cursor
Chances are, the operating system is corrupt.
Solution 1
1. Restart the computer, before entering the windows, press F8 to open the Windows Advanced Options Menu.
2. To enter the windows, select Last Known Good Configuration - enter. If that fails, repeat the process, select the Directory services restore mode. If that fails, repeat the process, select the Debugging mode.
3. After successfully entering the windows, press START - All programs - Accessories - System Tools - System Restore. Restore to a date when the computer is in normal condition.
Solution 2 (if the above solution fails)
Repair windows operating system with a bootable CD
Windows XP
1. Insert the bootable operating system CD, and restart
2. Perform booting from the CD room - Enter
3. Press enter - F8 - press R to repair the operating system
4. Wait until the process is complete. Finish
Windows Vista or Seven
3. Select Repair your computer - System Restore. If that fails, repeat the process 1, 2
4. Select Repair your computer - CompletePC restore. Restore a computer from CompletePC Backup Image.
Solution 3 (only for Win XP)
When done repair the operating system, drive C is detected: unknown or not formatted, it means the C drive for bad sectors.
To fix hard disk bad sectors, use the software HDD Regenerator bootable CD.
Nov 23, 2011 | Toshiba Computers & Internet
Computer in in start up mode and a ladys voice keeps saying we have a problem. instuctions say hit del to enter but it does not work
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Apr 10, 2011 | AOpen (MX4SGI4DN2PRE) Motherboard
Tip
Installation problems -Clean Boot/Install
Removing the software and reinstalling it using a "clean boot" may resolve the installation problems you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
4. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
Now download the latest version of the software for your OS from the manufacturer's website.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next , do the following:
4. Click OK
on Apr 25, 2008 | Logitech QuickCam Communicate STX Personal...
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
How to restore factory recovery system
If you still can boot it in windows, follow this:
Step 1: Click “Start” menu.
Step 2: Click “Programs.”
Step 3: Click “Acer Recovery Management.”
Step 4: Click the “Restore” button on the bottom of the dialog box that opens.
Step 5: Click “Restore System to Factory Default.”
Step 6: Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
Step 7: Click “Start” to restore the computer to the default factory settings.
If you can not boot to windows, follow this:
1. Restart the laptop
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process.
3. Follow the on-screen instructions to perform system recovery
May 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Getting orange flash light instead of green stable light on my dell optplex 520 and 745 what should to solve the problem
replace the power supply with a known good one. If that doesn't solve the problem then the motherboard is bad and would need to be replaced.
Jan 15, 2010 | Dell OptiPlex 520 PC Desktop
My acer aspire m1640 is booting up then just freezing or it says windows failed to start then scans for a problem finds one and says it can't do it automatic help
Tapping F8 key during bootup and get the window to run in Safe mode with networking.
When you login to administartor to window destkop.
1. Click Start --> Run --> Type MSCONFIG --> Click OK 2. On the General tab, choose Selective Startup 3. Uncheck Process SYSTEM.INI file 4. Uncheck Process WIN.INI file 5. Uncheck Load Startup Items 6. Click on the Services tab 7. At the bottom, check Hide All Microsoft Services 8. Uncheck all boxes in the window or click the button labeled Disable All 6. Click OK 7. Click Restart
1. Click Start --> Run --> Type MSCONFIG--> Click OK 2. Replace checkmarks in the items that you previously removed them from. 3. On the General tab, choose Normal Startup 4. Click OK 5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
Regards,
Ellin
Oct 18, 2008 | Acer Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
