JVC 31" TV Vertical Screen Jumping
I have a 31" JVC TV that the screen jumps / flickers vertically. This happens quite a bit when it is cold / first turned on. As it warms up the problem goes away. The other day I turned it on and it started jumping, I smacked the left side of the TV and it stopped. Then each time I smacked it I could make the problem re-appear. I've heard this is could be a cold solder joint and am looking for advice on which IC to re-solder. Any help would be extremely appreciated. Thanks, Neal
  • dragonmax Nov 05, 2007
    JVC AV27D201 same vert screen rolling/ jumping but responds to a smack or movement of entire set... cold solder? where is this located im an extreme novice
  • 398 Answers
The solder joints on the vertical output IC have cracked and need to be resoldered. The vertical output IC is mounted on a heat sink and has 13 pins all in one row. It is most likely labeled LA7838. Carefully resolder that IC and your set will play fine.
Posted on Sep 22, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
I've heard this is could be a cold solder joint and am looking for advice on which IC to re-solder. 1 whatever you have heard is correct as whenever you smacked the lelt side it works fine. 2 you will have to check loose contact in vertical section. your vertical ic might be located at the left side of the tv. 3 check any connector is loose near vertival section. 4 any preset is loose in vertical section. it is a simple problem if you are not technical person please get it done by tech person. as your tv is old & if it is done by tech person tell him to replace all elrctrolytic capacitors in vertical section. good luck.
Posted on Sep 21, 2007
SOURCE:
Ii have a old panasonic tv n the screen keeps jumping. How can I stop this?
Hello
The fault [vertical rolling, jumping] will be due to some value detereated electrolytic capacitors at the vertical output section of your tV. Repalce all the eelctrolytic capacitors [5 or 6 of them], on the vertcical output section on the main board.
Mar 14, 2012 | Panasonic Televison & Video
I cant stop the tv monitor screen from jumping it has something with the dvr
Hello What type of TV do you have, analog or digital? If you have an analog TV and the screen is rolling it is the vertical hold. Because the vertical hold operate on 60 cycle which the same as AC line cycle. The 60 cycle in the vertical hold is as a oscillator or timing circuit. When the TV pick up the image for the NV devise, they just don't mix. Why, because image intensifier tube in the NV devise is operation at 25 to 50K Hz or cycles. The vertical hold circuit pick up on the 50K Hz signal which mixes with 60 cycle timing circuit causing the screen to rolling with lines across the screen @ 60 cycles. Digital camera and digital camcorder with digital TV will help, or a image inverter that takes this 50k Hz signal and covert it to some that analog TVs can use. GB...stewbison
Jan 18, 2011 | Optics
White line across center of screen
cold solder in vertical ic or bad.
Apr 03, 2010 | JVC AV-27820 27" TV
White and purple flickering vertical lines. No image or sound.
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 04, 2010 | Sony KDL-46XBR4 46 in. LCD Television
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 19, 2009 | HP Pavilion dv4000 Notebook
No video on my JVC AV-30W475 30" flat screen.
It sounds like you have bad solder connections in the Vertical circuit or the horizontal circuit. The Vertical IC may need to be replaced if resoldering does not help.
You will need to call a good TV Tech for this repair.
Aug 09, 2009 | JVC AV-30W475 30" TV
I have a Sanyo Model number DS25530 that has a Flickering Screen
well sounds like vertical issue take to tv shop vertical ic or bad caps
Apr 03, 2009 | Televison & Video
Sanyo DS31590 31" TV vertical deflection
If the vertical is not defective or shorted there is a possiblity of bad solder connections on the vertical ic. If connections are good and has b+ voltage to the chip replace chip which is IC 501 LA7841 or LA7845 and change c511 (decimal point 1 film capacitor)
Dec 28, 2007 | Sanyo DS31590 31" TV
TV Shut off will not turn back on
the vertical i.c. is shorted, replace it.
Dec 20, 2007 | Panasonic CT-36D31 36" TV
Vertical lines jumping across screen
If the double image is in a differant color, then its your convergence IC's that need replacement. This is not a job for the unexperienced person. If you have no electronic repair experience, please seek out a pro to assist you in this repair. There are two IC's, about 3"X5" that are black in color and have STK with several numbers following them. Good Luck PS please dont forget to rate this thread.
Nov 02, 2006 | Mitsubishi VS-55705 55" Rear Projection...
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Ekse
