Question about Exercise & Fitness
Tuturi J661F stopped working - Error E1
Hi, I have the above foldaway treadmill. It was fine then later in the day wouldn't work displaying E1.
Any ideas please?
Thanks
  • 33 Answers
Your problem might be that a magnet has fallen off. Here's an illustrated tutorial that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
There is a small magnetically operated switch, speed sensor, that is activated by two magnets in the drive pulley on front roller left side. When I disconnected this it ran for a few seconds then showed E1. The screws had been done up too tight at the factory and cracked the magnet switch housing/mount, so if the magnet switch falls off you will get an E1 error.
Posted on Jul 20, 2016
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
Treadmill works for 30 seconds and then stops saying E1
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Oct 05, 2010 | Startrac Fitness Products Star Trac 3900...
After starting the treadmill 10 seconds later E1 apears on the display
Your problem is that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Sep 16, 2010 | Horizon Fitness Merit Fitness 725T...
E1 not ERR1 error appears on the display of diamond t300 york fitness treadmill??
Your problem might be that a magnet has fallen off. Here's an illustrated guide that will make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 04, 2010 | York Yankees Bedding MLB Comforter
E1 code
Your problem might be that a magnet has fallen off within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Apr 28, 2010 | Tunturi T30 Programmable Treadmill
Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Jun 07, 2009 | Exercise & Fitness
Exercise & Fitness Logo
1,231 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
