Question about Mitsubishi WS-65869 65" Rear Projection Television
HD setup, 480 to 1080 not working.
Same problem I have read before, with no real answer. I have connected HD rcvr to componet 1, with proper cables(RGB), on an HD chanel. I still have 480, is it like a video game where I have to push the combination of buttons on the remote to get my power move to work, or in this case my 1080 to work??? Is the change suposed to be automatic, or do I indeed need to change something???
  • Anonymous Dec 26, 2008
    Cannot get 1080i to show up only 480 with new HD cable box even though tv and cable box are both set to 1080i and using a hdmi/dvi cable
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Posted on Sep 22, 2007
Can't get the tv sound to come through the surround receiver
This question does beg for more details. For instance, some HDTVs have an optical out which can be hooked into the Denon. This works great when the unit doesn't have HDMI I/O. I have one such Denon unit [1312] which I bought for that exact purpose. It's all I could afford, and it works. You do have to have the rcvr set on TV or whatever the optical in goes to.
Or, some people have a newer Denon and setup their RCVR to switch and only one TV input from the RCVR. then it's the cable box connection you need to check/switch to. it's not simple, but it's not that hard either. I you need more help you can PM me.
Feb 10, 2014 | Denon AVR-1601 Receiver
Yamaha rx-v663. Want to watch cable tv while listening to cd (blue ray).
Don't think there is a way to make that happen with your setup
Dec 31, 2012 | Yamaha RX-V663 Receiver
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
When componet is hook up for hd
My first guess would be that the component connections are not matched. Check the component method and make sure that both the source and the TV are set the same. There are two methods:
1) RGB
2)Y,Pr,Pb
If the set is set for RGB and you are sending Y,Pr,Pb the picture will look a bit purple.
Dan
Jan 28, 2009 | RCA HD61W66 61" Projection HDTV
1st time using component video connections on my onkyo
Yes, switch to the video input that you are trying to configure (i.e. video 1-4). Press the menu button on the receiver or the remote and cycle to video settings. There should be a setting that says "video output" or "output" - set that to component. You may also have to configure the Input for that particular setting. For instance, if you have an HD tivo going into component 2 but you want it to be Video 1. Select Video 1, hit the menu button and scroll to video setup. Select video input setup and cycle it to component 2. Next, use the menu to cycle to video setup, select video output, switch to component. This should solve your problem. As a sidenote, you may also have to configure the audio in/out if you're using digital coax or optical. Let me know if this works.
Feb 02, 2008 | Onkyo TX-DS787 Receiver
Mitsubishi WS-65869
On the input section on the back of the tv it should say what formats it uses also make sure that you have in on a hd channel and make sure your using component cables and not the yellow white and red
Jul 11, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Cant see all of screen
You should have a button or setting on the remote that says "picture size" or "aspect". One of those is set too "zoom" mode which will cut off the bottom and top of the frames. You want it to be in 16:9,Normal or Full mode (or whatever your set call it) to get the correct aspect. Or if you have a HD satellite rcvr. you might of placed it in the zoom mode as well.
Apr 25, 2007 | JVC HD-52Z575 52" Rear Projection...
Coaxel and composite jacks produce scrambled picture, componite ok.
Bad hyper board = repair by qualified tech, PCB not available...
Feb 11, 2007 | Toshiba 50HX81 50" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
648 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
