Question about Microwave Ovens
Microwave suddenly went off while I was cleaning the inside of it, and won't turn itself back on.
My microwave oven went off while I was cleaning it, and won't start up again
    Scholar:
  • 192 Answers
You should not have cleaned it. No just kidding. It was probably just a coincidence that the fuse failed at the same time. fuse's are all ways the first thing that go's . Try replacing the fuse. If you need help . let me know I will walk you througt it. DFD
Posted on Apr 21, 2009
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
Mar 21, 2016 | Microwave Ovens
Turns on when door opened
There is an power interlock inside the oven that breaks the power connection to the magnetron when the door is open. Most likely, something is stopping the switch from opening.
Check for a small plastic probe on the door that may have broken off inside the oven keeping the circuit made. Otherwise, open the oven and see is some foreign object is keeping the connection made or if the interlock needs to be cleaned out so it can function.
Jul 11, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Think my fuse blowed
Generally, Microwave ovens have a glass fuse on the main filter board inside the microwave itself. Attempting to replace this yourself (opening the microwave covers) is not advisable. There are several components inside a microwave oven that run at 2000-3000 volts and though it is unlikely, there is a chance the capacitor on the high voltage side is still charged and presents a LETHAL hazard. A repair of this nature should be referred to a qualified technician.
Sep 05, 2013 | Magic Chef MCD1311ST Microwave Oven
The microwave suddenly turned off. I believe it's a blown fuse inside the microwave itself. is this possible? is there a simple way to fix it?
Sometimes there are fuses inside, but there are also high voltage capacitors that will hold power even with the unit unplugged. If you haven't worked on one before, it's best to leave this one to the pros.
Jan 31, 2011 | Microwave Ovens
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it)...
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Oct 10, 2010 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Panasonic Microwave NN-T993SF has no power. Was working and suddenly the power went out like it was unplugged. It is not our fuses or cord but something in the microwave itself. Is there a fuse or...
most microwaves do have an internal ceramic fuse either 15 amp or 20 amp the cover has to come off to locate it usually at the top just behind the control board. do not touch the high voltage capacitor as it holds a charge even when the unit is unplugged.
Nov 07, 2009 | Panasonic NN-T993SF Microwave Oven
Same Problem - Suddenly Died ~2yrs old, very light use.
Probably a fuse inside the unit. Can be caused by overheating or by door switches not working properly.
Sep 10, 2009 | Panasonic NN-P794SF Microwave Oven
Microwave turning on by itself
Sounds like a relay is stuck/activated by something. Causes are power surges, mice shorting wires, spiders and such creating bridges across the contacts on the circuit board. Not a DIY project unless you have some electronics background and know what precautions to take while inside the case. There is enough juice in there to seriously injure or kill a person. Eric
Jun 10, 2009 | Whirlpool MH3184XP Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
