Question about Dell Latitude D600 Notebook
HP Lattitude D600 Laptop freezes up
Problem continues on, my daughters HP Lattitude D600 freezes after 45 minutes of use. Hard drive seems to be running when it freezes. Running XP. She pulls and reinstalls the battery and it operates again. We scanned the hard drive with AVG, McAfee and Spy Bot and no viruses were detected. Advised to check "timer" on the computer-appears to be bad advice. Any other ideas out there? What about pulling the hard drive and resetting? Any help out there?
Chet
  • a1968ryan Apr 20, 2009
    The overheating suggestion is worth pursuing, Checking for patterns in programs being used when it freezes is also worth a try. She runs the computer with the AC when it freezes.
    Thanks,
    Chet
    Scholar:
  • 34 Answers
It could be a number of things. . Sometimes the unit will freeze when it overheats.. Have a look around the exhaust vents and see if there is excessive dust built up around there. If you notice any, you may have to take it in to get checked. If you are tech-saavy, then take it apart and clean out the CPU fan. Also make sure that there is good airflow around the vent when operating the unit.
If this is not the case, then you should take some notes to see if there is a trend when this happens. What sort of apps are running when it freezes at the 45 min mark. Is it only on battery? If so, its possible the battery is running out of juice and the software is not throwing the correct warnings - it just freezes the machine (this is exactly what my Asus EEEPC does to me when I let it run wayyy down on the battery - it freezes. However, it warns me a few minutes ahead of time). Try yours on AC and see if it has the same problem. If not, then its likely your battery. You may need to go in and tweak your power management settings to make sure that it warns you when the battery level is low.
Posted on Apr 20, 2009
Where is the hard drive located on the dell lattitude laptop
Take 2 screws out of the bottom of the laptop. The hard drive slides out of the side of the unit like the CD Drive would.
Jan 22, 2010 | Dell Lattitude D600 Notebook
I have a Dell C400. All of a sudden it won't boot. Can't even access BIOS. Display has nothing. Battery light keeps flashing from green to amber.
Remove the battery and the hard drive , use the charger and try to boot to BIOS. If it fails then the laptop is dead.
Jan 17, 2010 | Dell Lattitude D600 Notebook
I put a new hard drive in my laptop and i keep getting primary hard disk drive 0 not found what can i do
henry_holmes
If you are still having trouble with the drive being detected the problem may not be with your hard drive but the computer. If you got the same error on your old hard drive I would try it on another computer to see if it is detected. If it is then most likely there is a problem with the motherboard.
Let me know if you have any more problems or questions.
Issken
Jan 16, 2010 | Dell Lattitude D600 Notebook
Keeps freezing even after a SYSTEMS RESTORE & disc clen-up and deframentaion...help my daughters online high school test are freezing up during finals. Thanks so much
Systems can freeze for a lot of reasons. Some of them can be the following:
  1. Virus spyware infection.
  2. Hard drive lack of free space.
  3. System over heating
Possible resolutions:
  1. Run antispyware application like MALWAREBYTES available from download.com
  2. Systems need at least 10% of the hard drive free to function normally. If you have less than that free, then uninstall applications or delete files till you do have 10% free.
  3. Run the system on a flat hard surface. Clean out the intake and exhaust vents with canned compressed air.
If issues continue, then you may have hardware issues and run system diagnostics.
Dec 07, 2009 | Dell Latitude D600 Notebook
Laptop becomes idle after 10 mintues
problem is either motherboard or harddrive
Jun 28, 2009 | Dell Latitude D600 Notebook
Will over heating cause the computer to freeze?
D610's are almost always over-heating due to simple dust build-up. Our fleet needed to be cleaned out on a regular basis. Simply grab a can of compressed air at a office-supply store, or related, and aim it straight into the bottom fan, and back vents.
Unless you have squealing or your fan is not spinning at proper speed, or at all, your parts are fine and a simple remove of dust and debris should work.
If this does not solve your issue, please let us know. If this information was helpful, please take a moment to rate this solution. Thank you.
Apr 21, 2009 | Dell Latitude D600 Notebook
Laptop Screen Shuts Down after 45 minutes of use
i think you set the timer on your laptop make sure you dont have the timer on.
Apr 19, 2009 | Dell Latitude D600 Notebook
Hard drive not seen in dell latitude d600 after upgrade to vista
Your hard drive may need reseating.
If it still gives error hard disk not found then you have a faulty hard drive.
You need a new hard drive and then install Windows Vista
Mar 23, 2009 | Dell Lattitude D600 Notebook
Hard drive location
http://support.dell.com/support/edocs/systems/latd600/sm/hdd.htm#1123687
Dell Latitude D600 Notebook Logo
1,054 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
