Rank: Wiz
Rating: 79%, 526 votes
Do a virus scan first
FREE ANTI VIRUS
Try here its free
http://www.kaspersky.com/kos/eng/partner...If you can not access or open IE right click in and select Properties
then set the homepage to Blank!
SOUND RECORDING\MIC ON USB CAMERA
In Windows XP
Select the proper Audio Input Device (Sound Recording) under the Audio
Tab in Sounds and Audio Devices in Control panel. Usually it is name
after the USB Camera.
CONNECTION
Check your connections on Rear part of your PC. Lime is for Sound Out
usually a speaker, Pink is for Mic, Blue for Audio Input.
CLEANING
Using a dump clothe. Wipe the plugs with a twisting motion.
If all fails then You may have a Sound Card problem. Using a spare
Speaker or Headphone check it if it works. If its not then its
Defective and needs replacement. If its working then your Speakers or
Headphones are defective. Try fixing them by cleaning or checking the
Continuity of its cables using a analog Multi tester.
