Question about Stone Clearance: Black Granite Vanity Countertop Pre Drilled Holes - Solid
A bottle of skin oil was turned over on a granite counter top. It left an irregular stain. Is there anything to put on it to lift it out? Thanks
  • 247 Answers
Here is a website that might help.
Kurt
http://www.mrscleannw.com/tips/granite-stain-removal.html
Posted on Apr 20, 2009
My black granite countertop has a stain which must have soaked thru seal, now shows a whitish spot, How can I fix this? Thanks
Remove Water Marks/Stains from Granite Countertops ...
? 2:55
https://www.youtube.com/watch?v=VO571n_4Jns
Jun 10, 2011 - Uploaded by KristyU2178
... the water mark/stain from my black granite countertop in mybathroom. ... @TheJefferyjones The stains ...
Removing Stains from Granite Countertops - YouTube
? 5:51
https://www.youtube.com/watch?v=hPPFe8902Zg
Oct 1, 2010 - Uploaded by MonkeySee
I left a bag of sweet potatoes on my black granite and there were some ... @Oxidized181 yes I have lots of ...
Stains on Black Galaxy Granite - Countertops
Jan 17, 2016 | Home
Can i use linseed oil on my granite counters
you should not use linseed oil or any other oil on granite countertops unless the desired look is a darker stone. The oil may not penetrate depending on the color and density. Linseed oils are generally only for soapstone.
Apr 28, 2014 | Building Materials
Granite countertop
Granite needs to be color matched epoxied together at the seams. If they are sitting level and flush (and Solid) a home owner solution is to use matching silicone filling the seem then cleaning off with a good solvent. tape the top on both sides before starting. The second solution works to keep out food, but may not look great if they are not flush or have not been cut cleanly and the gap is not too wide. You will need suction cup turn buckles to pull them tight. Do not do any of the above if you are not comfortable with your skill level or feel it may damage your top. Granite can be stained using the wrong products.
Oct 12, 2013 | Dishwashers
Purchased soap desp. model #RP47280SS with no directions. Left white ring with dispenser on counter and used rubber washer and plastic nut on bottom. I can't get the dispenser very tight to the...
bobj50-
The white washer goes underneath the counter (with the nut) and the rubber gasket on top of the counter under the dispenser head. You may find it easier to tighten the assembly with this configuration. As for filling the bottle, unfortunately it must be unscrewed from under the counter in order to refill it.
Hope this helps.
Regards,
DIYpro
May 17, 2011 | Delta & Soap Dispenser
I am upset that I did an etching project and I accidently got some etching cream on my black granite counter tops. It looks like it is just discolored. But it sticks out like a sore thumb because it is...
Is it a genuine GRANITE counter top??? I'm surprised an etching solution damaged it... what was the etching solution for, glass, metal??? to be honest I would try to find a spot of the counter top somewhere that is not showing and do some testing before addressing the visible spot, first replicate the issue with the etching solution at the hidden spot (or on some left over peace of counter), than try different cleaning solutions (ask an expert on granite counter tops) if it does not work try a polishing solution or even some acids could bring back the colour...
Mar 24, 2011 | Microwave Ovens
I need to replace the stainless skin on my freeze
You will most likely need new drawer unit Warner's Stellian in Saint Paul, MN can help. For cleaning DeBruce Polish is the best.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Jan 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
New granite countertops big circle spots on.
They suggested a dryer because they thought the stone had absorbed a liquid and was causing the stone to darken. This is common on unsealed granite. If you put a sealer on the counter tops however, whatever it is you see there will remain under the seal. I would ask the installer to come out and take a look at it. If they are unwilling, the Home Depot has a cleaning kit sold in the kitchen counters area of the store made by a company you can call and they will ask questions about the problem and provide advice on how to fix it. They are extremely helpful with free suggestions as well as stuff you may be able to purchase to fix the problems. In any case, granite is sensitive stuff and while it is physically durable it seems to be extremely sensitive to stain and etching and learning about proper care, cleaning, and dos and dont's will save a lot of heart ache and time for you down the road. (For instance oil absorbing into the stone is a several day ordeal to fix). Good luck with getting the results you want. If you did find a specific solution please share it here.
Dec 28, 2009 | Jenn-Air JED8430 Electric Cooktop
I have Granit kitchen worktops how do i get wine stains and every day stains off Many thanks
There is a cleaning kit sold by Home Depot in the kitchen counter top area of the store in black bottles for about $25 or so. The company that makes these are experts in cleaning stone. I would recommend calling them. After you get the stains out you will want to seal the counters using their seal or something else that is recommended by the manufacturer of your counters. The process to seal is simple and should be done every time you notice water absorbing into the stone (or ideally before that starts to happen). Good luck and your posting of the specific advice received from Stone Solutions and what you did and the result would be greatly appreciated.
Sep 21, 2009 | Stone Clearance: Black Granite Vanity ...
Small chip in granite countertop
Well you should seal your granite counter at least once every two years because granite is pourus. Theres something called Granite Guard you can use to seal your counters and other different sealers as well. You can pick some up at your local home and garden supply store.
Apr 02, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
Stone Clearance: Black Granite Vanity  Countertop Pre Drilled Holes - Solid Logo
245 people viewed this question
Top Stone Home Experts
Donni Steen
john h
Gene Haynes
Are you a Stone Home Expert? Answer questions, earn points and help others
