Question about Whirlpool RMC305PD Microwave Oven
Whirlpool microwave combo rmc305pd touch pad doesnt always work
Toouc pad doesnt always respond
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Whirlpool Microwave
Sounds like the mounting tabs have broken on the plastic control panel frame. You'll probably have to order both the control panel frame and the membrane keypad since they are attached. You can't peel your keypad off the frame and put it on the new frame. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Search for model number as MT9100SFB0 Another option if you prefer not to replace the control panel frame is to glue it in place, probably from the inside, but you need to be sure the mating surfaces are squeaky clean and dry.
Posted on Sep 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: touch pad not responding
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Nov 25, 2009
SOURCE: Whirlpool GH6177XPS3 Touch Error display
I've got the same problem and error code. Did you ever find the fix?
Posted on Jun 04, 2010
  • 185 Answers
SOURCE: Whirlpool Microwave Hood Oven Model MH8150XJ (ten
probably a shorted magnetron or diode or both.
Posted on Aug 07, 2011
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
No display
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Jan 24, 2013 | Whirlpool RMC305PD Microwave Oven
Reads F2 doesnt work
F2 indicates a failure in the touch key pad. The part number for the keypad is 4393916 for white, 4393917 for black and 4393918 for almond color.
The part runs about $77.00. It can be replaced by removing the upper grille, then removing the one screw on top of the touch pad.
Jul 16, 2010 | Whirlpool MH7140XF Microwave Oven
Control panel not responding properly
this is a costly repair. when the touch pad or control pad is not working normally a new touch pad is required agin it is costly.
Feb 24, 2010 | Whirlpool MH7140XF Microwave Oven
Touch pad not responding
prototech@usa.net
Nov 23, 2009 | Whirlpool GH6177XPS Microwave Oven
Ge microwave HVM1540DN1BB button control pad stopped working
I am not familiar with the Whirlpool microwaves; however, I just had the same problem with an LG over the range microwave. Several of the positions on the touchpad quit responding to touch. In our case, it was the touchpad itself that was the problem.
The touchpad on our microwave was held in place with adhesive. We pulled it off and replaced it with a new touchpad. Everything works now. The only complication is getting to the connector which carries the signals from the touchpad to the microwave controls. We had to remove and dissassemble the door to get to that connector.
The touchpad cost about $26.00.
Oct 09, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Keypad on ge spacemaker microwave oven not working
Needs a new touch pad if it doesnt respond, you can check the connection between the touch pad and the pcb, but it sounds like there is an O/C on the pad.
May 18, 2009 | GE Microwave Ovens
Magic chef touch pad doesnt work
I don't have Magic chef, however, I would try hitting cancel, unplugging the microwave and waiting a few minutes, then plugging it back in to reset it. Alternatively, you could go to your manual under troubleshoooting. I wish that I could help you more with this. Good luck to you. Please let me know if you figure this one out.
Jul 31, 2008 | Emerson MW8626W Microwave Oven
Suggestions
check the touch pad or control switches, and check the control panel circuit, check the thermal sensors. check the wiring.
Sep 28, 2007 | Westinghouse WST3504 Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
