Question about Samsung LE22A457 22 in. LCD TV
Poor Sound - Brightness Too High
Elderly Family Friend Just Bought This TV
Finds the sound mushy & zizzy (Comb & Tissue Paper}
Brightness very High.
She is 130 miles from me and I have no idea of remote layout
or if it has sliding door or how to access menu
I know I know but it is genuine Thanks Andrew
Would external speakers wired in cutting out original be best?
Your recommendation appreciated. Not seeking HiFi but SubTitles is a bit defeatis on nedw TV
  • andrewfkarn Apr 21, 2009
    Thanks very much for the advice. I was inspired to ask if there was a MENU button on the handset and persuaded her to press which
    then listed Brightness Colour Contrast etc. Talking it through on
    the telephone she managed to obtain picture suitable for her.
    Thanks again Folks May you continue your good deeds
    Andrew
    Problem Solver:
  • 5 Answers
This sounds like something in the Power Supply/Regulation issue. Screen voltage to high and B+ to audio circuits to high. Never go in a TV and wire anything into it. You will create a sock/electrocution hazard. These chassis are live (all metal parts at line potential) and do not operate like the old sets that have have transformers.
Posted on Apr 20, 2009
My Polaroid z300 stopped printing pictures and keeps telling me to load it even though there's paper inside. How can I get it to print again?
It could be that the paper supply sensor isn't properly activated, or a new sheet isn't being picked up. Try removing all sheets of paper and inspecting with a flashlight.
I once assisted a frustrated elderly friend with a similar situation, and discovered that a white kleenex tissue had found its way into the paper loading mechanism! Her initial inspection had not detected it because it was camouflaged!
On another occasion, the rubber feed rollers didn't have enough friction to pick up a sheet of paper until they were cleaned with rubbing alcohol.
Dec 25, 2014 | Office Equipment & Supplies
47" philips lcd tv goes black but still has sound
Yeah the picture tube is old.... if it's a lcd or led then u're having prob's with display Circuits... call a techie and he'll fix it
Jan 11, 2014 | Philips 47PFL3603D/F7 LCD HDTV, 47...
My 29 inch crt has sound but no picture
Sounds like a high voltage power supply problem. With the TV on, check to see if CRT has a static charge on face of screen by placing back side of hand in front of it and feel for static charge. Also you could hold a piece of tissue paper in front of the screen to see if static electricity from the CRT attracts it. If no static charge is present, the problem is more than likely in the high voltage power supply. Unless it is something simple, like a loose connection, it would probably be cheaper to replace the TV. Do not probe around in the HV power supply while the TV is on--it could prove deadly.
Dave W.
Sep 14, 2012 | Samsung CW29M64NS 29" TV
I have a panasonic TH-50P V600 TV, the sound in
by any chance do you have the set in suround sound if you do change it back to stereo.. and try that most of todays set have poor sound and tiny speakers. because so many people connect there set to a theater system
Dec 04, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
No sound from the TV when the headphones are plugged in.
if you have a stereo unit(am+fm reciever) that has output to speakers, connect the out jack of the tv to input on back of stereo unit(aux in or cd input) then you can have output to headphone and speakers also.
Apr 07, 2009 | Sennheiser RS 110 Consumer Headphones
No signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Apr 26, 2008 | Televison & Video
Cant get sound from some of the channels!
Try locationg the "Play Seconday Audio" option in settings and change it either from YES to NO or NO to YES. An elderly friend of mine had the same problem and that solved it. He uses Time Warner Cable, not sure what you are using, but it is worth the try.
Mar 20, 2008 | Philips Magnavox 27MS343S 27" TV
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
Dec 12, 2007 | RCA F32450 32" TV
32 Toshiba TV no picture / bad pciture
Hello Suzid, It looks to me like you have a possible power supply issue (poor brightness on screen, shrinking of the picture, and initially no picture) This problem may put you in danger of electrical shock, so I would suggest that you not try to repair this set yourself. I would suggest that you take the television to a television repair shop.The power supply issue could be a low power or a high power supply problem.
Oct 03, 2007 | Televison & Video
Samsung LE22A457 22 in. LCD TV Logo
78 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
