Question about Hotpoint Aquarius WF000 Front Load Washer
Lights only swicthes on for 3 seconds on hotpoint wf100 washing machine
  • mikeote Apr 20, 2009
    Hi
    Sorry, no error number as the WF100 doesn't have a digital display.
    It is probably causd by damage which occurred when it fell over in the van on the way to my place.
    When yu turn the power on the lights go on for about 3 seconds, than go out, that's it =/
    I tried another appliance in the socket, socket worked fine.
    Regards,
    Mike
  • 298 Answers
I'm hoping that this can help you.
Hotpoint wf100 Manual
If not im sure that their tech support hot line can assist you
Contact information
Reply back if you need further assistance.
Posted on Apr 21, 2009
  • Mike  Petrowsky
    Mike Petrowsky Apr 21, 2009
    Ok for suspected damage I would definitely call for a professional repairman to come test and take a look at this unit. without a thorough inspection of the machine it will be tough to diagnose the problem or if it has been damaged to the point where it could eventually short and cause dangerous conditions.
    Genius:
  • 1,011 Answers
Dear,
is there any error code so that i go on track...
regards,
Posted on Apr 20, 2009
Hotpoint WF100 doesn't spin
its a stretch fit belt ,give it some application and it will fit
Dec 01, 2012 | Washing Machines
How to clean filter on wf100
There should be a flap or door on the bottom on the front of the machine. Open the flap or door and unscrew the filter.
Jul 31, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Wash enhance and on off light flashing.
solved it - kinked hose issue as well i think - hose had being lying loose behind machine - makes sense to attach hose to clips on machine.
Sep 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Looking to download hotpoint aquarius wf100 manual
Hotpoint user manuals can be downloaded from there web site at
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
If the link does not work miss out the bit from /hs onward and navigate through the site to the manuals download.
Apr 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf100 completely dead
have you check the glass fuse on the circuit board it might be at the bottom
shaun
Mar 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF100
Firstly, there should be only one hose, always connected to the cold supply.
The unit will heat the water to the setting you choose for the wash (40 - 60 - etc)
Secondly, if the unit is leaking water, try turning down the cold pressure, this will slow the supply pressure to the unit and prevent spray out from the detergent drawer.
Your supply tap should have an isloting tap on it, adjust this until it sullpies water at an acceptable rate.
Do this by feeding the hose into a bucket/basin and tweak it until it pours out - not sprays out.
This should alleviate any leaks around the machine.
Hope this helps.
Oct 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF100 Spin Hot
use a label maker they cost 15 to 20 and the labels last forever.
there are ways to stencil them on but they will come off unless you use plastic paint.
Apr 02, 2008 | Hotpoint Aquarius WF000 Front Load Washer
WF100 door wont open
The interlock has jammed, first try gently pushing the door frame on the latch side of the door and then hit the outer door frame with your fist, not too hard but a reasonable bang this may release the door, if this works spray a lubricant into the latch hole in the panel, open and close the door a few times before reusing, if this fails then you have to force the door open, the best way is to remove the lid and manouver the door lock from the inside, either the lock or the latck will eventually break, this is unavoidable, then replace the interlock and any other broken part.
Regards
Advisor
Nov 17, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Sep 18, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
75 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
