Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Not working on any programmes!
I have a Whirlpool 6th sense dishwasher AAA class No. ADP5966. It will only light up on the 1st setting. I can turn the dial but the light won't move. The on button double flashes every 5 secs. It won't run any programme. When you hold the start button in it drains the dishwasher for about 30secs, then the button just flashes with nothing happening. Water is being supplied to it and water can be drained away if you manually put water into it, but other than that nothing else is working.
  • Saxyhelen Apr 30, 2009
    I have exactly the same problem. The on off button is flashing twice continously, the program is stuck on normal and will only start draining then stops again. Please help. ;0)
The start light is flashing on and off and the programmer wont change to another programme it stays on the normal programme and the dishwasher will not start
Seems to be relatively common. Ma doing one now with that exact problem. If you hold button in for about 10 seconds, it should reset.(switch off then on again to push start.). If same action continues, the electronic module needs to be replaced.
Dec 31, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Cda dishwasher
green light on right flashing and beeping noise..Problem solved by thowing a few pints of water in the bottom of the dishwasher...must have 'primed' the pump..which must have been the problem; working fine now. David- Crosby
Apr 19, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool ADP5966
just choose another programme setting and hold the start button in for a few seconds. this should solve the problem
Dec 24, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
Nov 16, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool dishwasher
We had same problem with our ADP 5966. An engineer over the phone said he thought it was related to machine being unable to drain. I checked the drainage pipe connection to u-bend under sink, and sure enough, there was a major blockage. Cleared that and hey presto, problem solved.
Jul 31, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
765 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
