Question about Creda Washing Machines
Creda 1000 supaspeed washing machine, washing comes out very hot!
Is the machine hot feed/cold feed or both?
  • 1294 Answers
SOURCE: i have a creda simplicity 1000 front loader washer.
Maybe the pipes are not connected to the heater on the wall. You could heat your water in the machine, if there is a provision; most machines have it.
Posted on Dec 02, 2007
  • 74 Answers
SOURCE: Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Posted on Feb 17, 2008
  • 135 Answers
SOURCE: creda eco washing machine won't spin
i trust this problem is resolved.
Posted on Dec 30, 2008
  • 100 Answers
SOURCE: Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Posted on Feb 03, 2009
barkencoa
  • 3463 Answers
SOURCE: Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Thankyou.
Posted on Feb 10, 2009
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
Creda 1000 supaspeed manual
No spining ,i remove the brush holder clean it coz the brush stucked in and was not three , then mount it back, check for proper contact to rotor and on it back to normal- In a second fault the bushes was out of use so i purchase a pair and rub it to fit the size as it was not available on market, now it is running fine.
Oct 31, 2010 | Washing Machines
We have a second hand Creda Simplicity W100 washing machine and want to know if it needs to be connected to both the hot and cold water supply or if just the cold can be connected
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Jan 17, 2010 | Creda W100FW Front Load Washer
I need the manual for a creda supaspeed economy plus model 17064Echa642
The users manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/INDESIT/P%20640%20AS-_E
Kind regards,
Ian
Nov 29, 2009 | Creda Washing Machines
Im instaling a 2 yr old zanussi aqua 1000,it has a hot and cold feed,there is just a cold feed at the house
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=213690&brand=&model=&part=y-piece&style=washerhelp
Washing machine is a hot and cold fill, but I only have a cold water supply You can use a Y Piece connector (external link 4Washerhelp spares) to connect the hot and cold fill hoses to a single cold water supply. The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may be able to buy this part also from a DIY store like B&Q)
Oct 21, 2009 | Washing Machines
I have had my Creda 1000 Supaspeed- Economy Plus for about ten years. Just one week ago the program panel stopped advancing at the end of first rinse with all the water still in it. I turned it off and...
Crea8tivefeng,
I wish I could be of some help but the same thing just happened to me! I have also had this washing combo for almost ten years. I haven't yet tried looking at it as it just broke. I can be handy but I have never looked at a washing machine before. With out looking at it I wonder if it could be a belt not letting the spin cycle work. Maybe the dial is broken? If you have found a solution to the problem I would love to hear back from you.
Derek
Oct 07, 2009 | Creda W100FW Front Load Washer
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
try
Feb 17, 2008 | Creda W100FW Front Load Washer
I have a creda simplicity 1000 front loader washer.
Dec 01, 2007 | Creda W100FW Front Load Washer
Washing Machines Logo
129 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
