Question about HP Officejet J5780 All-In-One InkJet Printer
Scanner I get the following message when I try to scan: The scanner or camera is in use. Please try again later.
  • Bearbags Jan 20, 2008
    Cant get the scanner to work... Just says scanner and camera already in use
Uninstall then reinstall the drivers.
Posted on Sep 20, 2007
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
My scanner doesn't communicate with my computer but my printer does
Hi, there are many possibilities why your scanner is undetected by your computer. It can be its logical connection, scanner driver or the scanner itself.
If you have Windows operating system, please check Device Manager. In the Device Manager please check for the following:
1. Any yellow or red X's, question marks or exclamation marks related to the scanner.
2. Under the Category of Imaging Devices - Check for Epson Product name.
If IMAGING DEVICES is listed, test the scanner from PAINT as follows.
If IMAGING DEVICES is not listed then the scanner is not being recognized. Try another USB port or cable until the scanner shows up in the Device Manager. (The scanner must be on and connected in order for the computer to recognize it)
If you see an Imaging Device that points to your Epson Scanner or Unknown Device that has a yellow question mark or exclamation point, you need to update the driver.
Try to scan in Paint to isolate the issue between your computer and scanner.
To scan in Paint, do the following:
1. Click on START > ALL PROGRAMS > ACCESSORIES > PAINT.
2. Click on FILE then select FROM SCANNER OR CAMERA.
3. Choose COLOR PICTURE.
4. Scan.
If it does not work, it is possible your Windows Image Acquisition (WIA) service is not started.
To restart this process please follow the steps listed bellow.
1. Click on Start > Control Panel > Administrative tools
2. Double-click on Services to access the list of available services.
3. In the Services window scroll down to the bottom and double-click on the Windows Image Acquisition (WIA) Service.
4. Select the STOP option.
5. Click the START option to restore the service.
6. Try scanning again into Paint.
If it scans fine, try scanning from the application that you normally use. If you are still unable to scan or receive any error messages, try reinstalling the scanner driver or software.
If you have Macintosh operating system, please check Apple System Profiler if your scanner is properly detected. The reinstall the scanner driver.
If your scanner is still undetected, please contact your scanner manufacturer for any possible driver updates.
Nov 11, 2011 | Epson WorkForce Office Equipment &...
When i install scanjet 8270 on windows 7 professional.after complete they appear hp solution center on deskotp and photosmart. so the problem is when i try to scan documents or picture or other alse the...
Hi
Please go to the control panel and select the Scanner and Camera, hear you get your scanner, double click the scanner and try to scan the paper, if hear also give the same error then please reinstall your scanner driver,
click hear to download the driver
May 19, 2011 | HP ScanJet 8270 Flatbed Scanner
I have a radio shack pro96 i can not reboot it to restall the v scannfolder what can i do i have tryed everything to wipe it clean
Sounds like the motherboard is corrupted. Please try these steps again. Thanks!! Happy Scanning!!
I need to ask you this. Normally one bank can't be closed.
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Apr 11, 2011 | Radio Shack Pro-2096 Base Scanner
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
Perfection 1670 Flatbed Scanner: When I try to scan I get a message saying: "Can...
Do the following:
Uninstall the scanner from your computer
Restart
Re-install all software and drivers with the original CD * if you dont have the drivers check the manufacturars website *
Restart again
And then it should work fine. If this fails use the scanner wizard in Windows Control Panel and follow the step by step instructions.
May 18, 2010 | Epson Perfection 1670 Flatbed Scanner
My LiDE flatbed scanner cannot scan, it indicates that its processing callibration data, then posts an error message on screen and that's it. what do i do?
Please follow these steps :-
1- try to scan the image in MS paint.
just open mspaint by the RUN command.
click on FILE and select FROM SCANNER AND CAMERA
then try to scan.
2- Try to restart the scanner service from the services.msc
restart the system.
or
try to restart the system in safe mode then try again to scan the document.
press F8 for safe mode while reboot the system.
3- Try to delete scanner from the DEVMGMT.MSC
just click on scanner in the list and delete that.
it can be in USB list.
restart the system
or
4- Try to uninstall scanner's driver from the DEVMGMT.MSC
just type DEVMGMT.MSC in RUN command
then select the scanner from the USB device and right click on the scanner and try to uninstall driver.
then install driver from the cd or internet.
Thanks for choosing fixya.com
May 07, 2009 | Canon CanoScan LiDE 500F Flatbed Scanner
Keep getting this message: calibration cannot be performed. Pull out the film and place the film adaptor unit at Frame 1. What does this mean?
then try to scan.
restart the system.
or
restart the system
or
Apr 02, 2009 | Canon CanoScan LiDE 500F Flatbed Scanner
Canoscan lide50 does not scan
then try to scan.
type services.msc in RUN command.
restart the system.
or
restart the system
or
Jan 21, 2009 | Canon CanoScan LiDE 500F Flatbed Scanner
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
348 people viewed this question
Clive
Clive
