Question about Brother LS-2125 Mechanical Sewing Machine
Bobbin does not turn
Bobbin is not workin does not turn
  • 111 Answers
Stripped gears underneath?
Posted on May 04, 2009
How do you tighten the bobbin on a brother xl2500
Don't understand your question. What do you mean by "tighten the bobbin?" Are you asking about bobbin "tension?"
Aug 19, 2017 | Brother Sewing Machines
My Janome harmony sewing machine is totally jammed
1. Try to take out the needle. If this doesn't work take out the bobbin carefully so you don't get stuck by the needle. Also remove the bobbin case. (thing that the bobbin sets in)
2. Once you have the two out try to turn the hand wheel. It should turn.
3. Replace the needle. Clean the bobbin area thoroughly. Oil the race where the bobbin case rides. One drop is all it needs.
4. With the needle inserted and no bobbin inserted turn the hand wheel.
5. If it turns ok then insert the bobbin case and bobbin.
6. Does it turn? If it is a problem turning then you will need to get it timed from a maintenance person.
Nov 13, 2016 | Janome Sewing Machines
Bobbin not functioning in my sewing machine.
Consult your owner's manual. It sounds like possibly you don't have the bobbin threaded in the bobbincase properly. The bobbin must spin (either clockwise or counterclockwise per the manual) a certain direction and the thread needs to be threaded in the bobbincase in order for the bobbin to turn.
Sep 05, 2015 | Sewing Machines
I cannot get my Brother ES-2410 machine to fill the bobbin. I have followed the instructions but the bobbin spool does not seem to turn. Any advice please?
Grasp the big wheel on the right hand side and pull it out (to the right).
Thread the bobbin and put it on the bobbin spindle on top. Push the bobbin and spindle to the right. Turn on the machine and spin it up. The bobbin spindle should turn and the machine should not sew.
Oct 05, 2014 | Brother Sewing Machines
The bobbin thread keeps breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Jan 21, 2013 | Brother Sewing Machines
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
Singer touch & sew 640 bobbin won't turn
is the bobbin in the bobbin case correctly?
is the bobbin wound correctly?
try taking the bobbin out & turning it the opposite way
let me know if any of the suggestions work
Apr 07, 2012 | Sewing Machines
Bobbin tension is too tight. Need to find out how to loosen the tension on the bobbin.
if it's a bottom loader, use a tiny flathead jewelers screwdriver in the screw on the bobbin itself. turn it a 1/8th of a turn in either direction then hold the thread and bounce your bobbin. If the bobbin drops too fast, turn the screw the other way and repeat. Do this until your bobbin only drops about2-3 inches and stops. Tension should be set:)
Feb 20, 2011 | Kenmore Sewing Machines
Bobbin
IMPORTANT: Always use a metal bobbin, or the magnetized bobbin case will not be able to function properly, resulting in a lack of tension on the bobbin thread.
9a8cb19.jpg Step 1:
Turn the handwheel counter-clockwise until the needle is in its highest position. Raise the presser foot lifter. Pull the slide plate forward and remove the empty bobbin.
Step 2:
Place the filled bobbin into the bobbin case, and pull about 4" of thread from the new bobbin. Make sure that the bobbin turns clockwise when the thread is pulled, or you will not have correct tension when you begin to sew.
Step 3:
Hold the needle thread loosely with your left hand. Turn the handwheel toward you, first lowering the needle, and continuing to turn the handwheel until the needle comes to its highest position.
Step 4:
Lightly pull up the needle thread and pick up the bobbin thread which will appear through the needle plate slot. Then pull both threads to the back of the machine leaving a 4" thread tail. Push slide plate back in.
Hope this helps. -samson39
Jul 22, 2009 | Singer Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
67 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
