Question about Microsoft Windows XP Professional for PC
Original xp cd boots to dr-dos prompt
After seting the bios to boot from cd and the st booting device as CD, original xp cd boots to dr-dos prompt after rebooting.
    Scholar:
  • 154 Answers
It means CD is not gud, look for another CD
Posted on Apr 20, 2009
Corrupt missing C:\windows\system32\config\system no original windows xp oem disk cannot use recovery console cannot get to a c:/ prompt no floppies have cd rom bios does not support usb boot possiblity...
Your master boot record of the hard disk is damaged. I suppose you have access to CDROM through bios. But it is not clear from your question. Set CDROM as first boot device. Get a bootable CD & make sure that it contains fdisk utility. Boot from it & you will get a:\ prompt. at a:\prompt type fdisk/mbr & press enter. Your master boot record of hard disk will replace. Now you will be able to go to c:\ prompt. Use your your xp cd to recover your windows.
-sonsunny
Jul 14, 2011 | Dell Dimension 8250 PC Desktop
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Troojan virus affected how to remove
You could use "System Restore" to revert to the time when your computer is still in good condition or pressing F8 while still booting up and choose "Last known good configuration" at the selection prompt. Then use your default anti-virus after the repair. You could try to use a bootable CD to scan your computer. This is the best way to remove virus because the virus is still in inactive state when you boot to a CD. When you are booting to a CD you must change the booting sequence in your BIOS. You can download and burn Hiren's bootable CD and use the NTFS DOS to CHKDSK your hard drive or use the built-in mini-Windows XP and invoke CHKDSK at its DOS prompt. Hiren also has an anti-virus software on its collection. You could also download and burn a known good bootable anti-virus such as Kaspersky, Dr. Web, Avira, AVG, etc. and scan your computer.
Jan 03, 2011 | Computers & Internet
I want to reformat my aver aspire 4520 laptop, which runs on vista, to run on windows xp. none of the ways i found on the internet helped me as i either couldn't find the function required or it wasn't...
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
this will erase you operating system you have to have a operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
Dec 05, 2010 | Acer Aspire 4520-5582 Notebook
It states windows could not start because file missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM you can attempt to repair this file by starting windows setup using the original set-up cd-rom. I did...
Check that the Bios will allow boot from cd by going into the bios and nselecting DVD drive as master or first boot device.
Re start the notebook with the disk in the drive and then it will boot from the CD. Then try again to repair your system.
Hope that helps.
Nov 20, 2010 | Dell Inspiron 6000 Notebook
My computer was fixed by a person who installed xp pro on it but he didn't have a validation key. Well i found my original install cd with the xp home edition and i want to do a clean install to install...
really simple just turn put the cd in turn off the pc and reboot, your cd drive should pick it up on boot up from there its simply following directions
Jun 24, 2009 | Computers & Internet
First bootable device
ok first u have press the delete or F2 and go to the BIOS setting and sellect the first bootable device CD rom after save and exit.. after that u insert the cd of win xp. and install the win xp... if any problem cont me...
Apr 07, 2009 | Intel D945GCL Motherboard
OK I MEANT THE MACHINE IS NOT BOOTING BUT INSTEAD ITS SHOWING AN ACTIVE HYPHEN ON THE SCREEN. IT CANT EVEN BOOT OR READ OS FROM A CD.
Go into your bios settings and apply "Bios defaults",
Be sure the boot order is set to
1. CD/DVD
2. Hard Disk Drive
then save and reboot.
If the system boot, scan your drive with a good anti-virus.
If not, insert your Windows installation disk and reboot, press space if prompt to do so to boot on the CD. Reinstall Windows.
If it does not work, boot with a dos diskette, with fdisk.exe, delete all your partitions. Reinstall Windows.
Mar 27, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Want to install xp by caldera dr dos
The problem is hard enough for beginners . First :
1.DR DOS is used by ASUS . DR DOS isn't MS-DOS (Microsoft), just 99% compatible with it . You have access with it on whole HDD+cd/dvd but , because drdos will enable only 8MB RAM you can't install winnt.exe from i386 . There are at least 2 solutions :
a. if drdos is enable because u reseted BIOS try to change bios according to a better result (avoiding Caldera) and start a nice windows installation;
b. u may use another desktop/laptop until the first restart (in installation) ; u must try to use a computer with ~motherboard for best results.
Don't forget that DR DOS Caldera is almost every time used on ASUS MBs with all on board and you must have a PS2 keyboard/mouse to use any kind of DOS . I read sometimes that DRDOS is a soft used by Microsoft which it's wrong - there isn't any link between drdos and any windows system , genuine or not .
DRDOS problem might appear because it's a soft put on ASUS MB cd driver and , sometime, might be on a BIOS ROM .When u will boot with the MB cd driver in this kind of problem might occur .
Other way Caldera may appear is when u have a windows cd made careless with NERO and caldera will appear no matter the MB .
Mar 24, 2009 | Microsoft Windows XP Professional SP2
File msissing
if you have a boot-able cd with windows xp on ...just enter bios , and advans setings...boot sector and select the first boot device ..the cd-dvd drive ...and after press f10 to save satings ..reboot with the cd ...inserted..and follow the instalation ....the problem might be that your boot from cd is disabled on bios settings...be sure you at liest note somewhere all the names of your sistem drivers..so ya might look for them if needed or identify 'em from your drivers cd-es. Good luck !
Feb 22, 2009 | Microsoft Windows XP Professional
Microsoft Windows XP Professional for PC Logo
120 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
