Question about QDI Group QDI Advance 10T Motherboard
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
My motherboard is QDI Advance 10T and at her homepage it says that suports :Three 168-pin 3.3V PC133 DIMM sockets
Support up to 1.5GB SDRAM
Support 66/100/133MHz Synchronous DRAM and 66MHz EDO DRAM .
I have 1 ram 64 Mb PC100 and 1 ram 128 Mb PC100.May I use another SDRAM of 512Mb PC 133 together with them.Is it possible that I have 704 Mb Ram without causing a hardware conflict?
    Scholar:
  • 154 Answers
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Posted on Apr 20, 2009
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
I need to know the capacity for MEMORY AND THE TYPE SPECIFIED
According to the manufacturers specs these are the memory specifications you need, and the maximum the motherboard will accept...
3 x 168-Pin DIMM-socket
for up to 768 MB memory SDRAM
with 8, 16, 32, 64, 128 and 256 MB size
Dec 28, 2010 | Shuttle Slot A AI61 (MBAI61) Motherboard
My QDI advance 9 doesnt accept 256 mb pc133, i have single and duo sidded 256 mb pc133 and the maximum it gives to me is 128 mb per slot.
Go to this link http://www.epinions.com/S0478496-Advance_9/display_~full_specs
It shows that the Max Memory that it supports is 768mb, It is possible that the memory doesn't want to work together.
Try putting them in, leaving a slot open in the middle. Duo module in slot 0 and single in slot 1.
If doesn't work try the opposite way around.
your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | QDI Group QDI Advance 9 Motherboard
Not reading the correct memory
Well, depending on what your ram and how much you have installed. This motherboard only supports up to 1gig max.
Memory * 2 x 168-pin SDRAM DIMM
* Maximum 1.0GB
* PC133
No matter how much more ram you install, it will not read more than 1gig.
Aug 22, 2010 | Biostar M6VLR PLE133T Socket 370 mATX MB...
QDI Group QDI Advance 6T Motherboard memory
make sure you are putting in the correct ram and make sure both are in good, may be registering only one, or maybe one is bad. try them one at a time in each different slot. should tell you if both chips/slots work
Dec 01, 2009 | QDI Group QDI Advance 6T Motherboard
How can i know if a ram suits my Legend QDI
you got to options
1. following the indications of your motherboard documentation (recommended/best), if you need to find out details about your motherboard you can possibly download and use one of this tools to get info about your motherboard and possibly find the manual online in the manufacturer's website
2. the following page will check your system to find out what memory you have and what you need and up to how much you can go http://www.crucial.com/promo/index.aspx?prog=uslp_intel_fbdimm
3. checking on ebay: in the following links indicates that it should be low density:
Module Size: 512MB
PC133 SDRAM
UNBUFFERED
Non-Ecc
168 pins
3.3 Volt
Structure: 64Mx64=512M
Low Density: 2 Banks of 32Mx8
SPEED: 133MHz
CAS Latency: CL3
hope this helps
Nov 22, 2009 | QDI Group QDI Advance 10T Motherboard
Max ram for SY-K7VEM PRO
Two SDRAM DIMM sockets support up to 512MB
168-pin PC133/PC100 non-ECC, unbufferred SDRAM memory
This is what your M/board can use in memory
Aug 20, 2008 | Soyo Sy-K7Vem-Pro Motherboard
QDI Group QDI Advance 10T Motherboard Logo
343 people viewed this question
Top QDI Group Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a QDI Group Computer and Internet Expert? Answer questions, earn points and help others
