Question about HP Real Estate Marketing Assistant (y1800a) for PC
When I try to install hprema on a system that already has HP Real Estate Document Assistant 2 loaded hprema says " will now uninstall hpreda2". I say OK, then it asks "do I want to delete or keep the agent profile." I said either yes or no (doesn't matter which) then hprema says "can't continue, uninstall not complete"
  • 1 more comment
  • Anonymous Feb 22, 2008
    HP Real Estate Marketing Assistant IS NOT Compatable with VISTA--what do I do???
  • Anonymous Sep 30, 2008
    I go to ad/remove programs and the program will not remove from my computer. I called a Tech and he updated and cleaned up my computer and still the same thing... will not uninstall..
  • Anonymous Feb 24, 2009
    New Friend:
As per the my point of view you must reinstall your program and then start to run that file because some time unfortunately we delete some important file of our programs, which create this kind of problems. So first you just uninstall your program which you currently using and then reinstall the updates program.
Posted on Aug 31, 2015
3 Suggested Answers
SOURCE:
  • 48 Answers
SOURCE: Microsoft Word 2000 or later not installed
Better you can install a latest version of Word or if you have the setup file of Word 2007 install it or Do one thing
Install latest Windows and MS Office then install HP Real Estate Marketing Assistant
Posted on Dec 31, 2007
  • 197 Answers
SOURCE: Does HP Real Estate Marketing Assistant work with
I think it wold if it works with aney other windows based program it shald you may have th save the file /document in word 2007 format.??? let us know how it gose pleas
Posted on Feb 19, 2011
Does HP Real Estate Marketing Assistant work with Word 2007?
Feb 18, 2011 | HP Real Estate Marketing Assistant...
I have a problem with the installation of "HP Real
There is a good chance we can get this running for you, but it may be a bit tricky. I suspect that the operating system for the new computer is more recent than that on the old computer. Fortunately, the new computer probably has a compatibility mode that you can use. I'm assuming Windows XP as your current operating system, but Vista can do this as well.
Assuming you're installing from a CD drive, navigate to that drive (Start>Run>d: OK)
Now look for the installation program: Probably SETUP.EXE. Right-click on it, then choose PROPERTIES.
Now click the tab called COMPATIBILITY. Select the box "Run this in compatibility mode for..", then select the operating system that the software was designed for (should be on the packaging). Now click OK. You can pick another option if this doesn't work the first time.
Last but not least, try double-clicking the SETUP.EXE and see if you get better results.
We have other options, so respond back if this doesn't work.
Jan 12, 2011 | HP Real Estate Marketing Assistant...
I can't remove it it says setup failed to launch installation
you didn't say which system you are running so let's assume you are running winxp. go to my computer, programs and find the file that contains your HP real estate Marketing assistant and delete itl empty the recycle bin and restart your computer. see if that works if not I will suggest you run a program named regcure which if you can't find I will be able to assist you with.
Dec 06, 2009 | HP Real Estate Marketing Assistant...
Updated Word
go to control panel add remove program then ckeck mark on update buton top right corner rhen remove update from your pc then install again your software also try to remove win 2oo3 office theh nreinstall it.
Oct 07, 2008 | HP Real Estate Marketing Assistant...
HP 5400 Install Hang
had same problem with HP 110 Plus (plotter).
Found a previous install of a HP FAX left MANY bogus entries on the registry, I wipe them clean and now all ok.
Hope it helps.
Aug 17, 2008 | HP Real Estate Marketing Assistant...
crc is READ errors.
what is this install media
you never said, what media, CD/DVD or USB stick
nor how it was made. by you, or media came from maker.
crc is error checking system for files.
https://en.wikipedia.org/wiki/Cyclic_redundancy_check
it can happen 3 ways, one reading a bad CD
or writing your HDD. (bad hdd)
windows does the check both ways
and the actual HDD does it internally, and if Sectors in the HDD
are bad, it replaces them (unseen on the fly) until such day the HDD
runs out of spares and is DOOM.
we run SMART test on all suspected hDD
the more modern unstated windows by you, will tell you the HDD is failing early, W10 for example warns of HDD internal errors.
Simple answer
CRC is like dropping deck of cards to the floor
you pick them up , count 51, and now right away this deck is no good. no need to count suites. at all.
CRC is the big brother to Checksum (card deck answer)
MD5 is what we use to check large down loaded files for integrety
cheers !
Aug 04, 2017 | HP Real Estate Marketing Assistant...
Dec 27, 2007 | HP Real Estate Marketing Assistant...
HP Real Estate Marketing Assistant (y1800a) for PC Logo
250 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
