Question about Zanussi FJS1225W Front Load Washer
E90 Error on Zanussi IZ 12 Washing Machine
E90 Error has appeared at rinse stage and at the spin stage of the cycle. I have to turn off machine for a while in order to get it started again.
  • 183 Answers
SOURCE: zanussi washing machine
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Posted on Sep 01, 2007
SOURCE: LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Posted on Apr 22, 2008
kjmac
  • 97 Answers
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
kevin000
  • 1847 Answers
SOURCE: hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
Thanks
Posted on Jul 01, 2009
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded ยท E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Oko 72630. Why is it stuck on rinse cycle?
    Could be several reasons:
    - Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
    - Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
    According to your description I think that this is not a failure otherwise error E20 will be appears on display.
    Once the washing programme has come to an end, END illuminates on the programme progress display.
    If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
    1. After a rinse hold, the water must first be pumped out:
    - Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
    After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
    - Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
    - Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
    At the end of this programme step, the END indicator will illuminate.
    2. Open the door.
    As soon as the DOOR indicator lights up green, the door can be opened.
    Dado
    Aug 15, 2015 | AEG Washing Machines
    I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
    E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
    Basic Reset
    One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
    Feb 26, 2014 | Frigidaire Washing Machines
    E90 error
    If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
    Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
    Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
    Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
    The pump has a thermal safety cut out on it.
    If the pump gets too hot it cut out.
    Just put a new pump in and your all going again.
    Aug 05, 2012 | Fisher and Paykel Washing Machines
    Tumble dryer displaying E90 error
    do you have the machine's manual ? if you do try and find out what the message mean
    Mar 23, 2012 | Zanussi ZDC5350W Electric Dryer
    What is erro code 6e on a samsung washing machine
    Don"t worry too much about the error code, press pause, and then press pause again, the cycle should continue. If the counter does not countdown, ideally,as long as your washing is in the machine for 30-35 mins that should be ample time, then press pause and put your dial on the final cycle from rinse to spin, if this does not work, try picking a longer wash cycle, leave for 30-35 mins, then press pause and fast-track to your final stage of rinse to spin, Good Luck!
    Apr 16, 2011 | Washing Machines
    E90 error message appears on display. What do I do?
    Hi, E90 appears to be caused by faulty connectors to the main circuit board which appears in the bottom right corner, if you're looking at the washer from the front with the lid off (looking down into washer). This is fixed by reseating, cleaning the connectors.
    remove 2 screws at the back which secure the top,
    push the top backwards,
    unplug the connectors to the front panel,
    vibrations due to unbalanced load may have loosened them,
    push them firmly back in socket,
    pushed the top (back to front, make sure a plastic tab seats properly to secure front part of top panel) in place and fastened the screws,
    power on,
    run the machine empty for minimum cycle - rinse only.
    Feb 25, 2011 | Zanussi IZ161S Front Load Washer
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    Zanussi FJS1225W Front Load Washer Logo
    227 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
