Question about Dell Precision M60 Notebook
Dell Precision M60 won't start up
I have a Dell Precision M60, about 4 or 5 years old. This morning it won't start. When I press the Power On button nothing happens. It is plugged in, and there is a light on the power supply but there are no lights on the laptop which there usually are when power is plugged in. I have taken the battery out and tried turning it on with just the mains adapter, but no difference.
Sometimes when I hold the power button in for about 5 secs the power light on the laptop flashes briefly, but nothing else happens. Any ideas?
  • jmgthomas Apr 20, 2009
    Thanks for reply.
    Battery is connected. Does M60 not power up from mains alone without battery?
    Is there any way of telling if it is the battery rather than connection with the power supply?
  • rocket07 May 18, 2009
    Fan appeared to be working harder, caps lock was not toggling, turned machine off then no lights at all on console, power supply ok, tried with battry removed still no lights and no start up. Last turn off appeared normal, it was done in hope of untangling caps lock issue.
  • 90 Answers
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Posted on Apr 20, 2009
Can't use old laptop computer Dell Precision M60; Windows XP password lost-no way to open to gain access to computer. Would like to reset password.
Boot computer Into safe mode. Open command prompt type this.
Net user *
PRESS ENTER
net user (your user name) *
ENTER NEW PASSWORD
ENTER NEW PASSWORD AGAIN
DONE
Apr 28, 2012 | Dell Precision M60 Notebook
Precision m60 power not staying on
hi first check addopter if power work fine then check ram if ok check proccessor if ok press main chip on board then check shortage may bee any fet or capceters shorts
Jul 18, 2010 | Dell Precision M60 Notebook
Dell precision m60 press the power button the screen blinks for a second the lights next to the power button stay lite for about 3-4 seconds then the entire laptop turns off. ANy ideas guys?
You could have a bad peice of memory or a bad memory slot. Pull the memory out and try one peice at a time in each of the two slots. If you only have 1 peice you will need to either borrow a peice of the same memory or buy it. You also could have a shorted battery so pull the battery out if the ram is ok and try to boot. Another idea is the cd rom may have a problem so pull it if the ram and battery are ok. After doing all this if the system will still not boot the motherboard must have a short and needs replacement. This model also had an issue with the power board where the power button is. The connector on the motherboard was poorly designed and very sloppy. Over time it gets worn and causes a similar issue. The temporary cure is to press very hard on the power button to see if it will boot and then leave it running. You can also put pressure on the underneath side around the docking port and press the power button. This issue however requires a new motherboard. The M60 is almost the same as the D800 infact most parts are interchangeable. You could switch out the motherboard to a D800. I refurbish the D600 AND D800'S daily so I am fimilar to this issue. Let me know how you make out. Phil pmgibs1@verizon.net
Feb 23, 2010 | Dell Precision M60 Notebook
My precision m60 wont turn on
remove the LCD hinge cover, see if you can turn it on pressing the power button directly. Also the suspend switch in the hinge cover could be sticking.
Sep 20, 2009 | Dell Precision M60 Notebook
How to rebot dell laptop
Usually three ways.
Start-turnoff computer-reboot
Three finger salute aka hold down CTRL and ALT and then press the Delete key. That will either bring up task manager where you can select reboot or it will just reboot if you press it again (depends on os version)
Hold down the power button.
Depending on your model there may also be a reboot button that you can poke. It is usualy hidden on the bottom somewhere.
Jul 09, 2009 | Dell Inspiron 8600 / Latitude D800 /...
Dell M60
At the left of your power button, past the word PRECISION, there is a slot for a screwdriver. With the screen fully open, use that slot to remove the power and volume buttons. At the other end of the stip you removed will be the connector that connects the buttons to the motherboard. Reconnect it better.
Nov 26, 2008 | Dell Precision M60 Notebook
Dell M60 volume buttons
At the left of your power button, past the word PRECISION, there is a slot for a screwdriver. With the screen fully open, use that slot to remove the power and volume buttons. At the other end of the stip you removed will be the connector that connects the buttons to the motherboard. Reconnect it better. I had this problem too.
Nov 07, 2008 | Dell Precision M60 Notebook
Dell Precision M60 Notebook Logo
730 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
