Question about Wega Mininova EPU Espresso Machine
Black and decker spacesaver coffee maker
I have the black and decker spacesaver coffee maker. The device will only brew about 1/3 of the water and then it stops brewing. If I turn off the device for a bit and turn it back on and repeat this several times, I will get most of the pot to brew. It is about 1 year old. Any suggestions
  • 1 more comment
  • sfclifton Dec 29, 2007
    Space Saver will only brew a half cup before stoping. It must be turned on again to continue brewing
  • dipasqualeju Aug 04, 2008
    my [email protected] spacemaker bews slow and takes awhile to brew.
    it has slowed down quite a bit.
    help
    jd
  • jcp_kv Oct 17, 2008
    Our black and decker spacesaver coffee maker started brewing very slowly and now has stopped drawing up the water from the reserve so now we get nothing. Is there a switch or part that can be replace to solve this problem?
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
Posted on Jun 01, 2009
I need the replacement part of the coffee maker that keeps the water in the tank, black round gasket with a spring tell me more or where I can go and get replacement parts for it.
Thank U
Star Litle
Posted on Sep 24, 2008
    New Friend:
Needs cleaning, I use whie distilled vinegar fill to 6 cup lne with vinegar let half run thru cut it off for 30 minutes to soak cut back on after 30 minutes and let the rest of the vinegar go thru then follow by 2 pots of fresh water presto should wor great.
Posted on Mar 30, 2012
Mine did that when it got older (build up). I ran white vinegar through it a couple of times, then a couple more with water. Worked like a charm.
Posted on Dec 08, 2007
SOURCE:
My black and decker coffee turns on but wont brew
You have a problem with your internal hot water heater which for most folks ( the vast majority who can not take apart a coffee maker and change its internal components) this means that your coffee maker is dead
Jul 05, 2014 | Black & Decker Coffee Makers & Espresso...
My black & decker coffee machine stop brewing coffee, sound like is going to keep working but is not .
Does the display work? Does the platter heat up when it is turned on to brew? If yes to both, this string might address the problem. Email me at the posted address if you need the part.
Jan 10, 2011 | Black & Decker Spacemaker 10-Cup Coffee...
I just have the regular Black & Decker coffee maker and I have the water in it and the filter with coffee, everything you are supposed to do. It used to work just fine and then one day it stopped...
Sounds like you might have coffee oil build up. I would suggest soaking the Brew Head Screen, unscrew from the brew head where the coffee oils come into contact with machine, and filter holder in a coffee oil remover or dezcal.
Remove the screw if your filter basket has one and do not screw too tight when putting back together or it will happen again
Dec 10, 2010 | Black & Decker Coffee Makers & Espresso...
I put the coffee on to brew and it stops after a few cups
If the display works and the platter heats up when it is turned on to brew, this might be the problem and solution. Please read both (scroll).
May 30, 2010 | Black & Decker Spacemaker 10-Cup Coffee...
Black & Decker TCM800 won't go all the way through brewing cycle
I have the TCM700 and it would turn off before the brew completed.  This was because it had some sort of buildup from use.  The manual recommended to brew with white vinager and water.  The exact mix was in the manual, but my wife just did all vinager.  Worked great.
Nov 26, 2008 | Black & Decker TCM700 Coffee Maker
Stops brewing, have to turn it off then on again
This problem seems to happen quite often. If the symptoms are similar to those posted in this string try the solution posted at the bottom. It seems to fix it most of the time.
Apr 14, 2008 | Black & Decker Spacemaker 10-Cup Coffee...
Directions on how to use my Black and Decker Espresso Mio coffee maker
Be sure the red rubber gasket is in place and clean (ridge side in) and bottom water cup is screwed firmly on to avoid leaking.
HOW TO USE:
1) Fill the bottom water cup with cold water up to the inside lip.
2) Set funnel into bottom water cup
3) Fill coffee basket with expresso grind coffee and level off. (Do not tamp or pack). Make sure it's filled to the top.
4) Place filter onto coffee basket and set coffee basket into funnel
5) Place brewer over bottom water cup and screw firmly into place.
6) Place unit with lid in the center of a microwave oven set on high for 1-1/2 minutes. If boil over occurs, reduce the brew time in 10-second increments until no boil over occurs.
7) Grasp handle to remove unit from microwave when finished brewing.
8) Remove lid and check the level of espresso in the brewer cup. Standard brew is at least 2 oz. If you don't have this level brew, replace lid and microwave on high another 10 seconds. Wait 20-30 seconds for bubbling to stop.
CLEANING/ADDITIONAL BREWING:
1. Under cold running water, unscrew the bottom water cup. CAUTION: It is normal for some water to be left in the bottom water cup. Both the coffee basket and any water in the bottom water cup will be extremely hot! If you prefer, allow the unit to cool for at least 3 minutes before unscrewing it.
2) To brew additional espresso, rinse Funnel, coffee basket and filter, then repeat brewing steps 1-8 above.
3) Parts are top rack dishwasher-safe -- hand washing filter is recommended.
Mar 10, 2008 | Coffee Makers & Espresso Machines
Wega Mininova EPU Espresso Machine Logo
1,858 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
80stech
Guy Tzur
Guy Tzur
Level 1 Expert
Vitally Alcher
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
