Question about Dell Vostro 200 PC Desktop
Won't boot..getting 2 short beep codes..have tried memory that i know is good.
When i power up (vostro 200) i get two short beep codes. i have tried using memory from a dell xps420 that works fine but i still get the beeps and nothing on the screen
  • majic750 Apr 20, 2009
    have tried crucial 667 & 800 that i know is good,but still won't boot.
  • aj 1000 Jul 07, 2012
    i was working on a dell vistro 200 and it kept beeping and would show anything on the screen so i did like i use to with my old dell and took out the internal battery and the system started to boot up. i recommend for you to try this and see if it helps if so you will need to by a new internal battery this should help in the future.
  • 90 Answers
Its the problem with the memory only. the memory u get from dell will noit suite ur pc. try changing the same type and speed memory
Posted on Apr 20, 2009
  • pvc73 Apr 20, 2009
    Look..remove ur old memory..take it to the shop and buy the same category ( i mean speed,type etc)
    And if  u are using 2 SIMS u have to put 2 SIMS and u have to fill the first 2 slots.ie If u got 2 SIMS old memory and if u r trying single  to put single SIm  it wont work
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
I purchased 2 GB chips to try to increase the speed of my desktop. After putting in the chips my computer won't boot back up, my monitor is black and the computer is making a constant beeping nois
OK. First, I'm assuming that you have a Dell Vostro 200 as per the topic title. That said, you machine has a maximum memory capacity of 4GB. So, if you added the 2 - 2GB DIMMS in slots 3 and 4, leaving your original memory in the machine, you will have problems. You must be using DDR2 667 or 800 MHz RAM and the two DIMMS must be in slots DIMM1 and DIMM2 ( closest to the processor). No more than that can be installed.
Apr 03, 2012 | Dell Vostro 200 PC Desktop
Dell vostro 200 4 beeps then with f2 starts
here is the explanation of what can be possibly wrong,
1 long, 2 short - Video adapter error: Bad or improperly seated video card
Repeating beeps Memory error: Bad or improperly seated RAM
1 long, 3 short-Bad video RAM or video card not present
4 short Keyboard communication failure: Bad keyboard controller or keyboard
This is what the typical explanation is. To avoid assumption, i will need info on *********** board...thanks,
Mar 19, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
My computer at start up beeps 3 times and won`t boot
Try booting up in safe mode. Press power on button and press F8 until you see a list appear. Go in under safe mode and see what the problem is....Hope this helps....
Nov 17, 2009 | Microsoft Windows XP Professional With...
Pc beeps 4times y?
4 short beeps
Your problem could
be a bad timer. The system timer failed to work properly. It will
require motherboard replacement.
1 long and 3 short beeps
Memory test failure. An error has been detected
in the memory over the first 64K. Try replacing the memory, and if
that doesn’t do it, the motherboard.
Beep codes are the beeps you hear from the
PC speaker when you turn on your computer. They are your computer’s way of letting you know what’s going on when there is no video signal. These codes are programmed into the BIOS of the PC.
Nov 10, 2009 | Dell Vostro 200 Desktop Computer
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
1 beep every 3 seconds
The system is having a problem accessing the system memory to refresh it, a problem either with the system memory or with the motherboard itself.
Sep 09, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
4 short beeps on vostro 200 monitor shows black?
http://support.dell.com/support/edocs/systems/vos200/en/index.htm
the above link will allow you to download pdf versions or view HTML versions of the Dell manuals for your machine.
4 beeps is RAM read/write failure
if you recently installed new RAM (memory) you should check to be sure that it is compatible. If not, you might just have a loose memory stick.
just remove and re-install memory modules making certain to seat them firmly.
!!!! Very important ..before touching memory.. be sure to discharge any static from your body - by touching anything grounded (I usually leave my tower plugged into a grounded outlet and make sure the rocker switch to the for the power supply(the switch on the back of the computer) is turned off.
Aug 09, 2009 | Dell Vostro 200 PC Desktop
Short but rapid beep code when powering up emachine
The beep code most likely is either video card or memory.
If you have a video card or can borrow one that you know it works try it first, if that doesn't resolve your issue try the memory.
You can take the memory out and have it tested to see if it is defective.
Go to this site and get the Beep Codes, http://www.computerhope.com/beep.htm
I hope this helps.
Good Luck.
Feb 26, 2009 | E-Machines eMachines Desktop PC
Dell Vostro 200 PC Desktop Logo
1,710 people viewed this question
Alun Cox
