7-blinks denotes a fault with its digital processor board. If you wish to get more details about the blinking codes to Sony TVs, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or
type in the brand name and model number to of your set, to its
search box, and press 'Enter' or view it in Mosaic /
Timeslide option.
SOURCE: Bravia KLV-S40A10 HDMI input
I agree with your solution and you are correct in that you lose very little quality by using component instead of HDMI. there are A/V receivers that transcode HDMI inputs to component; as far as I know that's the only other option
SOURCE: Sony KLV-S40A10E Where are the
get the scart cable connector connect to the TV and the home theatre
SOURCE: i have sony KLV-S40A10, and
Your TV should have component inputs to connect your PS3 to. You will have to get an adaptor such as appears on the link I have provided. You will only be able to use resolutions such as 480p, 720p or 1080i since component does not support 1080p. Hope that helps : )
http://www.brighthub.com/link/header.aspx?u=http%3a%2f%2fwww.amazon.com%2fPremium-Resolution-Component-Cable-Playstation%2fdp%2fB0013OM528%2fref%3dsr_1_2%3fie%3dUTF8%26s%3delectronics%26qid%3d1241533894%26sr%3d1-2%26tag%3dbrihub02-20&p=34502&returnUrl=%2felectronics%2fhome-theater%2farticles%2f34502.aspx
SOURCE: My klv-s40a10 tv turns on
Hi sandersonkie,
Sad to say because 4 flashes of the led light at the front panel is an error code for faulty "LCD Panel". This is the expensive parts on the unit, almost same cost of a new set if you are going to send it in for parts and labor. Check if your unit is still under warranty/extended warranty period, avail it because the manufacturer will fix it for free. If not, new unit is more practical than to send it in.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
