You can try deleting the file while your in Safe Mode. Try booting your PC in Safe Mode first and then delete the file. If it still does not work, the best thing would be installing a third party application like Unlocker to actually delete the file. Unlocker can be downloaded here:
http://www.filehippo.com/download_unlocker/
To use Unlocker, simply right-click the folder or file and select Unlocker. If the folder or file is locked, a window listing of lockers will appear. Simply click Unlock All and you are done. Thank you.
you will need to connect your camcorder to your computer
click start click on my computer to open from there you should see your camcorder then right click to select open you should see the data/files in there select what you want to delete right click select delete or you can right click select format this will delete all data on hard disk
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If you are getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Have you tried simply renaming the files to .avi extension and see if they can be opened/played? Data recovery software tries to identify the file type, but does not always get it right...
will its pre installed so you need to uninstall it using a PC, connect your phone to your computer access your phone memory and then delete or uninstall the file if its lock try unlocking it by right cliking the file and go to properties. if the video is save from your memory card then you need to go to options and unlock it and delete it, the second option is connect your memory card to a card reader and delete the video and the files that you dont need.
