Question about 2000RS-M Remote Starters Manual Transmission with Two 5-Butto
Car no Longer resposnding to remote starter or alarm
I took my car to get a diagnostic run on it. There was one message that had to be reset in my computer system on the car. After receiving my car back from the shop, my car would no longer respond to my remote start or alarm arming requests. Now the transmitter is just flashing continuously and as stated, there is no response from the car when I press any of the buttons on the keychain piece.
  • lil_hot_10 Apr 20, 2009
    The remote makes the noises expected when you press buttons, the car just doesn't respond. I have not checked the battery in the transmitter inside the car, but the light is flashing continuously and I am not sure what that means.
Did you try checking the battery in the remote?
Posted on Apr 20, 2009
It sounds like the mechanics may have disconnected the vehicles battery probably causing the remote to come out of sync with the actual remote start module .. it can be re-programmed, i google everything and usually sends me in the right direction,
Posted on Feb 02, 2010
    Problem Solver:
  • 13 Answers
Its in valet mode
Posted on Jan 10, 2010
My Nissan Quest 2000 does not start at all. The battery and the starter are fine. The problem has to do with resetting the alarm system. Can anybody help me with this problem?
you must do a search for the owners manual it will have the sequence in it for programming the remote control to reset the alarm you must disconnect the battery cables then reconnect the ground first then connect the + when the alarm sounds press a button on the remote control to shut it off if this works it should now disable the starter disable circuit and let the car start make sure the remote has a fresh battery in it LATER MAN!
Aug 22, 2014 | 2000 Nissan Quest
1991 toyota celica starts but alarm wont turn off
Most car alarm securty systems can be silenced by inserting key into door lock and cycle it. Runs of a simple switch that's attached to lock cylinder.
Oct 26, 2017 | Toyota Celica Cars & Trucks
My viper 5902 central controller won't response
Replace your Batteries on your remote control sounds like the batteries are not giving enough power ,so the radio in the remote to trigger the alarm to disable the alarm is not strong enough.Its like the power of the batteries show light but its not strong enough.
Jan 08, 2014 | Vehicle Parts & Accessories
Car is "dead" but battery/alternator/starter are all in working order. Hornet is causing this.
Sounds more like a faulty battery terminal to me from your description ,try cleaning and make sure its tight then smear with petroleum grease.Clean terminal with a kettle of hot water first
Jul 26, 2013 | Cars & Trucks
So the big one with the screen on me took a **** awhile back. so i was only using the black one, but now the dog ate it? If i use the key the alarm goes off. HOW DO I TAKE THIS OUT MY CAR?
Hello my name is Israel and I will help you. You can still use the alarm but you will have to do a couple of steps. Enter the vehicle. The alarm will sound. Insert key and turn to the 'run" position. Push or set the override button and alarm will turn off. The remote should be easy enought to replace. If you want to replace it, let me know and I will try my best to get a remote for you. Good Luck.
Feb 19, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
Nov 08, 2010 | 2000 Volkswagen Cabrio
1995 volkswagen passat vr6 wont start the injectors are getting fuel but its not getting fuel to the engine. The injectors are getting spark and the fuel pressure is good.
if it fires then dies, you have to reset the alarm system with the key/remotes???otherwise you need to plug in the diagnostic computer(saves hours of "fun")
Jul 27, 2010 | 1995 Volkswagen Passat
Scytek 5100 RS-2W system Problem
How do you reset the remote, alarm. I have a scytek two way security alarm, remote start. I can lock and unlock my vehicle, however the remote start and alarm won't work. When I press the middle button to have the car start it just beeps, and when I lock my car it just locks it doesn't beep to let me know the alarm is on.
Please advise, do I need another alarm, or just reset it.
Claudia
Aug 14, 2009 | 5000RS-2W Remote Starter with...
Car alarm stopped working.. Car wont start
the jetta has a faulty alarm system from the factory i have been working on one in my shop. the alarm moddule is inside the dash behind the light switch and has a 10 pin connector and a 6 pin connector. this can be bypassed if you disconnect both connectors and jump the two large wire on the 6 pin connectors, these wires operate your starter. the car will start and run but your alarm will no longer be active. the door locks and everthing else will still work. the only issue i am having is the factory radio isn't working because it is controlled by the alarm. but worse case scenario i can use an aftermarket radio if need be.
Feb 20, 2009 | 1994 Volkswagen Jetta
2000RS-M Remote Starters Manual Transmission with Two 5-Butto Logo
580 people viewed this question
Top Scytek Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Scytek Vehicle Part and Accessory Expert? Answer questions, earn points and help others
