Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
TI 84 plus
I have a calculator that has a very slow response time. A key most be pressed for about 5 seonds before it will register. The same key will not register twice in a row, the calculator is at room temperature.
I had the same problem. Found a posting on Youtub of someone messing up their TI-84 for fun by sticking a paper clip in it... One on the comments noted that dust in the data port can also cause it to not work right. I did not see anything dirt or dust on/in my TI-84. But I went ahead and took a can of compressed air and blasted the data port. Problem solved, it's been working fine ever since... If you have a receipt, and it's less than a year... TI replaces for free... other wise it cost $55 + $6 for shiping... 1-972-917-8324 is their number... Why it's not an 1-800.... I don't know... Hope this helps
Posted on Sep 26, 2007
  • ArthurTechno Sep 14, 2010
    My TI84 got some water over it durin gtransportation and became SLOW: response to key press 2 seconds, not 2x same key, not working 2nd-[on] = [off].
    I tried the solutions I read on the internet: blowing compressed air in the I/O hole. In fact you are then trying to blow air between the I/O metal connector and the plastic of the case: a very small hole that comes into the TI84 right above some electronic components. The blowing did not work, probably because the water made a mess with stuff and dust already in that small hole.
    This is what I did, but notice it is only recommended for people with experience in electronic-repair!
    1. Remove 4 AAA and backup battery (remove the screw).
    2. Remove 6 screws on bootomside with a very tiny TORCX screwdriver.
    3. Lift the bottom of the case by using 1 or 2 flat screwdrivers, taking care not to stick them into the TI84 and by using more force that you like for this delicate machine.
    4. Fold the aluminium halfway a little back.
    5. Check the components behind the I/O port: are the clean?
    if not clean proceed with cleaning as described in next step, otherwise you have another situation than mine...
    6. Gently brush the components clean, using a very small, flat and stiff artist paintbrush.
    7. Additional you can clean the area with a soft paintbrush wet from white petrol (available in a drugstore) (NB I am Dutch and do not know the right word for 'wasbezine')
    8. Let it evaporate.
    9. Fold back teh aluminium, take care of the triangular edges.
    10. Additional you can put a small cottonwool in the space in the plastic bottom-case on the spot where the USBconnector is, to make sure the aluminium will make contact with the USB.
    11. Same on I/O side to prevent new dirt to enter the TI inside.
    12. Click the bottom back in place.
    13. Put 4 AAA in place and test your TI84....
    14. Put the 6 screws and backup battery in place again.
    So that was not easy to find out, especially the removing of the bottom, but I am happy I did, because it saved me 120 euro, and I have still a beatifull new small screwdriver.
    Success to you,
    Arthur.
THANK YOU!!!
THANK YOU!!!
THANK YOU!!!
This saved me from having to buy a new one, cause my calculator is 3yrs old, and now it works again! Thank God! and Thank you!!
Posted on May 01, 2008
OMFG!
I have been searching on Google and found this post.
I thought it was a crazy idea but it really worked!
Thanks dude
Posted on Dec 11, 2007
SOURCE:
Not registering when I press the 2nd key
The 2nd key is not supposed to register anything. It puts the calculator in a waiting state until you press a valid key.
Nov 27, 2013 | Texas Instruments TI-89 Calculator
Can not set date on sam4s er-180
SETUP DATE & TIME
1. Turn C key to Program Mode.
2.PRESS "1300" - "SUB TOTAL"
3. H - H - M - M - X/TIME (H: 2 digits of hour, M: 2 digits for minute)
4. M - M - D - D - Y - Y - X/TIME (2 digits for Month, Day and Year)
5. PRESS "CASH"
Thank You
Team
ACP ONLINE
Aug 27, 2013 | Sam4s ER-180 Cash Register
I get black "lines" going across the screen when i hit the graph button. It will graph also,but you can barely see the graph. Help pleae.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 04, 2013 | Texas Instruments TI-83 Plus Calculator
My calculator is extremely slow and i cant fix it
Here is for you. From the TI Knowledge base.
Why does my TI-84 Plus or TI-89 Titanium respond slowly to key press entries?
Issue/Symptom: When making key press entries, the product responds slowly
If a piece foreign material such as a pencil lead is lodged in the I/O port of the calculator, it may create a short causing the calculator to respond slowly to key press entries.
If the piece of conductive material can be removed, it may restore the calculator to normal operating condition.
If the material cannot be removed, contact TI-Cares Customer Support to proceed with an out of warranty product replacement.
If conductive material is not lodged in the I/O port and the calculator responds slowly to key press entries, contact TI-Cares Customer Support for further troubleshooting and resolution.
Sep 08, 2011 | Texas Instruments TI-84 Plus Silver...
I have a Casio MS-8TV calculator and want to change the VAT rate to 20% (usage in UK), please. Val
How do I program tax rate into my calculator?
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
^Top I am having a problem registering the ClassPad 300, it keeps telling me my product key is wrong.
Enter only the numerals, not the letters.
^Top What features do our calculators have?
The attached chart shows comparisons of the different calculator models. This includes graphing, scientific and printing calculators. download the chart here
^Top What is the [F CUT 5/4] switch or [DEC] F, 0, 2 button for?
The HR-8TE/HR-8TM have a [DEC] key with F, 0, 2, and 5/4 over it, while many other calculators models have a switch labeled [F CUT 5/4].
The button or switch can control rounding off to a certain number of decimal places. F is floating point (no F indicator on screen), 0 rounds off to 0 places after decimal point, and 2 rounds off to 2 places after decimal point.
The 5/4 applies to either the 0 or 2 modes, and describes the type of rounding off that is performed. The calculator will round down if the digit after the one you are rounding to is 4 or lower, and round up if the digit is 5 or higher.
^Top What is the [5,4,3,2,1,0 ADD (2)] switch used for?
This switch is used to determine how many decimal places your answer is displayed in.
ADD (2) is often used for monetary calculations, so that it is not necessary to enter the decimal point. It is automatically placed two decimal places from the end for cents. For example, entering 123 will display as 1.23.
^Top Why do I get 111.1111... when I calculate 100+10%?
This is a markup on price procedure. The formula is as follows:
Markup%=(Markup Price-Cost)/(Markup Price)
^Top Why do I get the wrong answer when doing a percent calculation?
Make sure that you are following the correct procedure.
Adding 10%: 200 [×] 10 [%] [+]
Subtract 10%: 200 [×] 10 [%] [-]
^Top What tests are calculators permitted for?
AP Calculus requires a graphing calculator.
Any graphing or scientific calculator is permitted on the following as long as it does not have a QWERTY keyboard, electronic writing pad or a pen-input/stylus-driven interface:
PSAT/NMSQT, SAT I
SAT II Math, IC & IIC
AP Statistics (graphing expected)
AP Chemistry
AP Physics
May 27, 2011 | Casio Parts Cash Register PC Desktop
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 17, 2011 | Texas Instruments TI-84 Plus Silver...
Where do I go to find an on-line manual for TI 5045 Sv Texas Instruments calculator?
TI-5045 SV
ii
English.............................................................. 1
Fran?ais ............................................................ 6
Espa?ol ............................................................. 11
Portugu?s ........................................................... 16
Examples, exemples, ejemplos, exemplos .............................. 21
ILLUSTRATIONS ¦ FIGURES ¦ ILUSTRACIONES¦ ILUSTRA??ES
Removable tab
Languette
Leng?eta extracci?n
Alavanca usada para o rolo
Ink roller
Rouleau encreur
Tamp?n de tinta
Cartucho de tinta
English
Your Texas Instruments calculator has a built-in printer for producing a permanent record printout of
your calculations with negative numbers printed in red. A big, easy-to-read display also enables you to
check entries or perform quick calculations without printing.
GETTING STARTED
OFF ON PRT IC GT
POWER
1. Connect the calculator to a proper power outlet (110-120V or 220-240V
where available).
2. The calculator is turned on by setting the POWER switch to the PRT
position.
Inserting the paper (see illustrations 1, 2, 3, and 4 on page ii).
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding it back in the
direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the
calculator.
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the
calculator.
5. Press & until the paper is in the printing position.
Replacing the ink roller (see illustrations 5 and 6 on page ii)
1. Turn the calculator off and tear off the excess paper.
2. Remove the printer cover by pressing down on both sides of the front edge and sliding back in the
3. Remove the old ink roller by lifting it with the removal tab.
4. Insert the new ink roller into the compartment and press down gently until it snaps into place. Close
the printer compartment.
Note: The old ink rollers should not be refilled. Replacement rollers can be obtained from your local
retailer. The warranty does not cover ink roller replacement.
SELECTION SWITCH SETTINGS
OFF ON PRT IC GT
POWER ROUND
: 5/4 9 + F 0 2 3
DECIMAL
TAX
SET CALC
Set the POWER, ROUND, DECIMAL and TAX switches as required.
Note: The TAX switch is spring-loaded to return to CALC when it is moved to SET and released.
The switch settings are summarized in the following table:
SWITCH SETTING FUNCTION
POWER ON
PRT
IC
GT
No printout is provided; however, the display can be printed by pressing
4.
The printer provides a printout of your calculations but does not count them.
The printer is on and an item count of additions and subtractions to or from
the register is printed when sub-totaled or totaled.
The GT position controls whether or not the totals from the independent add
register are accumulated in the grand total register.
ROUND Rounds the result of a calculation to the selected number of decimal places.
5/4
9
Truncates the result to the selected number of decimal places.
Rounds the result up or down according to its value. For example, when the
DECIMAL switch is set to 2, the result is rounded up if the third decimal
position is 5 or more and rounded down if it is 4 or less.
Rounds the result up to the selected number of decimal places.
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: :
DECIMAL: 2, TAX: CALC
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: 5/4
Press Display Printout Press Display Printout
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.66 6¦ =
36¦66 ?
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.67 6¦ =
36¦67 ?
DECIMAL + Add mode: All results are given with two decimal places. For addition and
subtraction only, a decimal point is automatically placed to the left of the last
two digits entered, unless the number already includes a decimal point.
F Floating mode: Any results are displayed and printed with the maximum
0 2 3 4 Fixed decimal mode: Sets the number of decimals to 0, 2, 3, or 4.
TAX SET
CALC
Lets you enter a tax rate to perform tax calculations.
Stores the tax rate. Pressing ! or " after a tax rate has been entered,
adds/subtracts the stored tax rate to/from the value in the display.
Ex. VAT = 17.5 %
100 + VAT
Ex. VAT = 17.5 %
235 - VAT
Setup: PRINTER: PRT, DECIMAL: F, ROUND: 5/4, TAX: CALC
Move and hold the TAX switch to SET. Press 217 L 5 and release the TAX switch. It
automatically returns to CALC. 17.5% is printed.
2 0. 0¦ C
100! 117.5 100¦
17¦5 @
117¦5 ?
2 0. 0¦ C
235" 200. 235¦
N35¦ @
200¦ ?
Note: The most common setup is POWER: PRT, ROUND: 5/4, DECIMAL: 2, TAX: CALC. Use these
positions for the examples unless other settings are given.
KEY DESCRIPTIONS
Basic keys
I Clear Entry: Clears an entry, enabling you to enter another number in its place. Note
that this key does not clear the add register.
2 Clear Key: Clears the add register, any pending operations, and the display. 0.C is
printed. Does not clear the memory.
( Right Shift: Deletes the right-most digit entered from an entry before an operation key is
pressed. Shifts the remaining digits one place to the right.
L Decimal Point: Enters a decimal point.
4 Date/Non-Add: Prints a date (such as 12¦10¦96) or a number for reference purposes.
Does not affect calculations. This entry is printed on the left side of the printout, the date
or number preceded by the # sign.
& Paper Advance: Advances the printing paper.
Addition and subtraction keys
9 Add: Adds a number to the add register. Displays the cumulated result.
: Subtotal: Gives the intermediate total from the add register. Using this key does not
affect the contents of the add register.
. Subtract: Subtracts a number from the add register. Displays the cumulated result.
E Total: Gives the total from the add register, and then clears the register.
Multiplication, division, percent and margin keys
? Multiply: Multiplies the number in the display by the next value entered.
' Divide: Divides the number in the display by the next value entered.
3 Equals: Completes any pending multiplication or division operation.
> Percent: Calculates percentages, ratios, add-ons (e.g. of VAT), or discounts.
# Gross Profit Margin: Calculates the selling price of an item when its cost and gross
profit (or loss) margin are known; also used to obtain a price excluding VAT.
Ex.
Cost: 594
Profit margin: 40%
Press:2 594 # 40 3
Answer:
Selling price: 990
Gross profit: 396
Ex.
Selling price including VAT: 252
VAT %: 20%
Press: 252 # 20 . 3
Answer:
Selling price excluding VAT: 210
VAT: 42
/ Grand Total: Gives the grand total of the operations previously performed and stored in the
Grand Total register. Every time a total is obtained with E it is cumulated into this register
(printout shows G+) which is only cleared when / is pressed twice. During long
calculations, if / is not used, this re
Jan 16, 2011 | Office Equipment & Supplies
My ti84 plus won't turn on
Hi ezheng1000,
A battery reset procedure should bring your Ti 84 Plus back to life.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me that anybody could make the same mistake. And of course, the calculator will never come on if the batteries aren't in correctly.
The process below should reset your calculator.
Please be prepared to re-install the calculator's OS if you run through this process.
1). Pressing the [2nd] key followed by pressing and releasing the [Up Arrow] key. This adjust the contrast in case the contrast was to low. Keep repeating if necessary for about 10 seconds and, then go to the next step. If calculator comes on and responds to key functions your done.
2). Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],
message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. If calculator starts responding to key functions your done.
3). Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
4). Steps to re-installing the operating system:
~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS.
5). Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
6). If the above process did not work. Try re-doing the procedure and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying and follow the procedures.
Jan 07, 2011 | Texas Instruments TI-84 Plus Silver...
My ti-84 plus it does not respond to the function + or - OR other function, & it come up to display very slow ,slow. thanks
Hi xvbanh,
You need to free up some memory. Try clearing your RAM. Your calculator should operate properly afterward.
Go to [2nd] [MEM] [7] [1] [2]
If your calculator still won't let you delete the RAM memory try the procedure below.
Jan 06, 2011 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
310 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
