Question about Toshiba 57H82 57" Rear Projection Television
Wavy picture on all video inputs except component video toshiba 57h82
I had a slight wavyness happening on the top section of the screen that got better when warmed up. Also had a wavy picture on all video inputs across the entire screen. Then replaced the caps on the hyper board & it solved the wavy section on the upper part of the screen but I still have a wavy picture on all other video inputs across the entire screen. The component video input is crystal clear. If any one has any answers what else is wrong? Please let me know?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Make sure you replace all the 10uf caps and that the connections are good....
Posted on Oct 19, 2007
6ya staff
SOURCE:
Distorted picture with wavy lines..
SOUNDS LIKE A CAPACITOR GOING DOWN ON BOARD OPEN BK LOOK FOR BULGING HEADS
Sep 28, 2017 | Sony Grand WEGA KF60WE610 60" Rear...
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Samsung 50 HLN5065WX has wavy lines on analog input
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Jul 16, 2010 | Samsung SP50L6HX 50" DLP HDTV
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
PFM-42B1 VGA picture is very wavy
Sounds like the logic board. Is it the same on all inputs ?
May 21, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Toshiba 50H12 Rear Projection TV wavy screen
There is a Hyper Module mounted right behind the video inputs board. in most cases you can replace the 10uf surface mounts carefully not to tear the foil. and the set will return to normal. or replace the H/M board. this board is soldered 4 tabs on bottom of main board and then pulls out. good luck list of caps cz52(may not have this cap).. cx261 cx270 cx230 cx178 c514 cx221 cx250 cx241 cx541 cx670
Dec 11, 2007 | Televison & Video
Top section of the picture gets reversed and compressed
Dear simon, Seems like a simple problem. In all likelihood, one of the Electrolytic Capacitors in the vertical Output stages has failed.It could also be a cold / dry solder, as symptoms seem to disappear when you tap the set. But, do not try anything thing at home. A proffessional Techie should fix it up in 15-20 mins. Definitely worth the spend.
Aug 02, 2006 | JVC AV-27230 27" TV
Toshiba 57H82 57" Rear Projection Television Logo
404 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
