Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Panafax UF 885 replace battery
I changed the battery but there is received faxes in its memory.I could not get them.What will I do?
  • WiPer May 11, 2010
    Changing the battery has nothing to do with whether the documents are stored in the memory or not (unless you power off the machine).
    You may have switched on Memory RCV, in which case all documents will store into memory and not print out until you ask? see below:
    "FUNCTION", "8", "5", "SET"...then make your choice.
    Or, there will be another message on display or another symptom?
    President:
  • 3,085 Answers
Turn the machine off for 10 seconds.
If the display shows 00% there is nothing in memory.
Posted on Aug 20, 2009
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
I want to delete the memory from my panafax uf 885 fax machine.
Press
Function
7
monitor key slowly 4 times
* star key
6
scroll down to SHIPMENT SET
set
wait for machine to reboot
Nov 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 low battery on display how do you change the battery and what size is it and where is it
Pull up and open the doc feeder. Push the large white tab hanging down towards the rear to release the battery holder....it's hard to do.
The battery is a CR-2032 available anywhere.
If there is no white tab to push, somebody has lost the battery holder.
Oct 08, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Can i re-print the document form the memory of the fax machine?
no, you can only print out a journal to show what fax number it came from.
Aug 03, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
What does the code mean? How do I fix it?
051 means the printer motor is abnormal. I would try replacing the toner cart then switch off/on in the first instance.
Apr 14, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panfax uf 885
If it happens on all printouts, and not just from one sender, then replace the toner cartridge. That will clear up most image related issues.
Jan 18, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
200 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
