Question about Saeco Classico Espresso Machine
Saeco Classico is tripping the GFC outlet
Hi, Our Classico trips the GFC outlet as soon as it's switched on. Has anyone out there experienced this and know what might be causing it? Thanks!
  • JCNelson Jan 27, 2009
    Is this something I can replace at home.. the heating elelement.. or is there more involved?
    Sergeant:
  • Saeco Expert
  • 223 Answers
Your machine has a bad heating element and is ground out to the boiler ground. You will need to have the boiler rebuilt.
If you need service you can contact Cerini Coffee Services in New York. More information go to www.Cerinicoffee.com or go to saeco's website to find a local service center.
Hope this helps!
Johnny
Posted on Oct 12, 2007
Coord is fine tried many differant outlets, bu as soon as i plug it in the circuit braker trips.Any help about where the short is?
65 AMPS? That's drawing a LOT of power.
Is it tripping the breaker even before you pull the trigger?
If yes, I would use a continuity meter to start checking the various components. In particular, see if the switch is stuck in the ON position.
Unless you are experienced in tracking and performing electrical maintenance problem solving, this may be a situation best left to a repair shop.
Cheers
Mar 13, 2016 | Dewalt DW303 Heavy Duty 65 Amp...
Tip
My Saeco has started to trip electrical fuzes when switched on. Started when...
Here's a few Tips for the countless number of people having problems with the Saeco Line Super Automatics Machines.
These are more Suggestions if you will on what you can do that will help your machine last as long as possible.
Tip 1. Surge Protector. Get one and use it on your machine. About half of the problems associated with saeco's revolve around a power....or lack of power problem.
Even the smallest Surge can send your machine out of whack. Worse yet if it loses power while in mid cycle, it can jam the brew system.
Tip 2. Bottled Water. Coffee is 90% Water, so by contrast quality water will increase the quality of the cup. Try an artisan water like fuji or italian bottled water, or even filtered water. This small tip will not only keep your machine insides clean, it'll make for a way better espresso.
Tip 3. Ditch the Oiley Beans. All Super Automatic Espresso Machines, even the 20,000 dollar commercials have one major flaw. They Hate Oiley Coffee Beans. Why? Its simple, Oiley Beans Gum Up the inside of the grinder and brew drive system and clog them.
Another Reason to Ditch Oiley Beans? Being a 2nd Generation Artisan Roaster Oiley Beans scream a few things. Oiley beans are usually over roasted. The oil on the beans isn't a good thing, the oil represents the flavor oils from inside of the coffee emerging out. Once they become oxodized the coffee loses flavor almost immediately. Oiley beans are also a sign of beans that have aged, which again, is not a good thing. Proper Espresso Should have very little to no Oil on the beans with a Uniform Color Darker then a city roast.
They Only Time there is an exception is with a french or dark roast, where the ashy tones are allowed.
Best Advice here is try to find a local roaster. The quality is usually better then any of the commercial corperate counterparts and your actually supporting people like you. What kind of people is that??? People who have a genuine love for coffee and want people to share that love.
Tip 4. Descaling. Even with bottled water the machine should be descaled every other month. You have a variety of options here. I personally use cleancaf for its ease of use and the fact every packet has the instructions on them.
Tip 5. Brew Group Cleaning. Clean the Brew Group with Soapy Water. No chemicals necessary. You'll also need to purchase some silicone lubricant which is sold by saeco. It must be food grade. The lubricant is applied around the inside ridge of the puck area of the brew group. The first 3 coffee's on the machine should be tossed there after to clear it of residue.
Tip 6. Turn Machine off after each use. When you don't need it, don't leave it on. Leaving it on for long periods of time creates air pockets inside the boiler of the machine and can dry out the inner gasket of the boiler unless you have the new J Style Boilers that come with the newer lines from Saeco.
Tip 7. Be careful of your grinder. Firstly, I tell people every day. This machine is not ment to make commercial quality espresso. Its just not possible. It was ment to make for a better experience than the traditional italian moka pots that make fairly terrible coffee. If you want a stronger coffee, then the answer is in itself, try other coffee's.
The machine enhances good coffee, and by comparison, enhances the flaws in bad coffee. Inferior Coffee's will have little crema and bad taste. The machine will try the best it can to accomodate the coffee. The Elongated pre infusion cycle help take even the worst coffee and make it look like it gives increadible crema. The proof comes afterwards, where the crema will decipate from the bad coffee's but will stay strong on the true espresso blends.
Setting the grinder any lower then 2, regardless of the model, it warrent for clogging and/or damaging the unit. If the coffee is too fine, it'll clog the unit, and usually cause the brew drive to strip the gears and even worse, i've come across cases where its even broken the brew drive.
This concludes my Tips for Keeping your Saeco functional post. I hope this helps people and gives them incentive to step out of the box when it comes to conventional coffee's that are on the market.
on Jun 08, 2008 | Saeco Royal Professional Espresso Machine
Gfci trips heater not turned on
GFI is Ground Fault Interrupter (or GFCI - Ground Fault Circuit Interrupter) It is doing its job, telling you that there is a short in the unit or wiring. Have a certified electrician check the wiring and unit.
May 17, 2014 | Pentiar Pentair MiniMax 100 BTU Natural...
My Saeco Classico has problem. The pump is working
It sound as though the boiler is blocked by scale. May also be the coffee filter that's blocked. I am not familiar with this machine, but assuming that it's just a manual espresso machine, try running it with the filter handle removed. Any water emerging? If so, the coffee filter cup and/or filter handle outlets may be blocked. If there is only a small flow the boiler is almost certainly blocked with scale and descaling may cure the problem (do the first run with the filter handle off the machine. Next run with it on)
Oct 22, 2013 | Saeco Classico Espresso Machine
Electrical GFC wall outlet for oven keeps clicking off within 60 seconds of setting a bake temp. Has ES 100/105 Electronic Oven Control. I suspect problem with Resistance Temp Detector (RTD). Stove top...
Good morning, try plugging the unit into a regular outlet. GFI outlets are notorious for tripping when used with large appliances. They are very touchy for safety reasons. A large current draw could be interpreted as a short and will trip. Hope that helps.
Jan 29, 2018 | Frigidaire Ovens
The water does not get got enough. I replaced the thermostat, it did not resolve the problem. The water is still warm.
Did you replace the 95 deg thermostat or the 127deg thermal switch ?
Normal temperature control works like this, you turn on power and the boiler heats up. When it reaches 95 deg the thermostat will open and turn off power to the boiler, when it then cools down a little the thermostat will close and it will heat up again.
If the thermostat should fail in the closed position the boiler will continue to heat past 95 deg until it trips the 127 deg thermal switch which is a safety feature.
In your case maybe the 127 deg thermal switch is faulty and opening earlier than the 95 deg thermostat.
Nov 11, 2010 | Saeco Classico Espresso Machine
Gfci trips. Hi - I have had my Saeco for 10 years now. Since earlier today the gfci trips whenever I am trying to use it. Any ideas? Thank you!
GFI safety trips whenever it detects moisture. Normally this happens when water splashes over when filling or brewing coffee. This has happened to me several times. You must dry the machine out totally inside and out. I have used a hair dryer successfully both times. It is possible that you have a short circuit. If you want to veryif that it is moisture and not a short circuit, plug your unit into an outlet that is not GFI protected. If it kicks the breaker, then you definately have a short circuit in the machine. This would require dismantling the machine to find where hot wires have come into contact with bare gound.
Sep 13, 2010 | Saeco Vienna De Luxe Espresso Machine
My machine won't do anything when it's turned on. It blows the fuse in the kitchen every time. I looked in the back and nothing appears to be grossly burnt or destroyed. Any suggestions? I'm a mess without...
It is possible that the boiler over heated and blew the element, disconnect one of the legs and turn machine on, if it trips breaker, then replace element.
Sep 08, 2010 | Saeco Classico Espresso Machine
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
Tripped a breaker
sometime the kitchen has gfc outlets around the walls and one of them tripped. but not likely , it sounds like the microwave fried some valuable circuitry.
May 12, 2008 | Goldstar MV-1501 Microwave Oven
Saeco Classico Espresso Machine Logo
204 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
