Question about LG 42LC2D 42 in. LCD HDTV
LG tv color problem
Hi - We have an LCD tv (32 in.) that we have had for about a year and it just displaying yellows and greens strangely (e.g., green baseball fields look like a pale avocado color and people's faces look yellow). We tried adjusting the color controls but it didn't do much so we went back to the default. Any suggestions? Thanks so much!
  • Anonymous Oct 13, 2008
    I have the same problem, but my cables are all plugged in properly...what else can i try to fix the color issue?
Just like in Solution 3. Color was off. Looked in back and cables "appeared" to be ok. However, I disconnected the cables one by one and amazingly the color returned. So make sure your color cables are truly connected.
Posted on Feb 25, 2012
  • 1 more comment
  • SueNell Dillon
    SueNell Dillon Feb 25, 2012
    Forgot to say disconnected and reconnected the color cables.
  • Gisele Apr 08, 2013
    I had the same problem and checked my cables on the back of my TV AND my cable box, sure enought my red cable was disconnected from the cable box. Problem solved! Thanks for your help!!!
    I had the same problem and checked the cables on both the TV and the cable box. Sure enough, the red cable was disconnected, problem solved! Thanks for your help!!!
    New Friend:
  • 5 Answers
This is a known LG problem.
Return your set for repair.
Posted on May 14, 2010
    New Friend:
Red colour problem
Posted on Sep 10, 2013
    New Friend:
  • 3 Answers
As infuriating as it is to see an expensive appliance bite the dust a week or so after warranty, we all forget the the law is on our side. Any appliance that costs a reasonable amount of money should be expected to last longer than 12 months. My $2500 LG Plasma died 2 months after the warranty expired, and of course LG didn`t want to know about it. One call to LG from consumer protection to remind them that a $2500 TV should last at least 4-5 years, resulted in my Plasma being repaired free of charge. I could tell that they wern`t happy about it, but they knew I was in the right. TRUE STORY!
Posted on Jun 06, 2011
I had the same problems, called LG customer service, advise to check components cable, and make sure they were all blugged in correctly, ans sure engough, the red cable was discontected ,and after correcting that, the problem was solved
Posted on Oct 01, 2007
SOURCE:
When I hook up DVD player to 32inch LG television there is no color on the TV it plays in black and white. Why?
first check color level setting on the tv when on av source input. double check input you are using, yellow video input (not green)
then try another device in that same input, then try the DVD player on another tv. The problem will be either DVD player or incompatibility or bad main board in TV, but usually a DVD or compatibility problem(cheap DVD player)
Mar 22, 2015 | LG 32LD450 32 In. LCD HDTV
Why is desktop green like theres way to much yellow hue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
The colors are going out in Vizio E320VL. Can I fix this by replacing the main board or is there another solution?
Sounds like a faulty Timing Control board, I had the same problem except yellows showed up green.
Apr 03, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
Excess green and yellow in KDFE50A10
Absence of Blue color is the fault. The t'Con board or panel should be suspected. Contact any experienced service technician.
Aug 29, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Nov 28, 2009 | LG 27LC2R 27 in. LCD TV
Red or green tint on LG LCD 32" TV
Misaligned white balance adjustment. If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 14, 2017 | LG Televison & Video
Color problem with Samsung 40 in LCD HDTV
Check your component cables. You have 3 colors coming in. Red,Green and Blue. Make sure the Red cable is good. You can do this by substituting the red cable only, or just change all 3 cables
Best regards
CircuitCity
Nov 25, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
LG 42LC2D 42 in. LCD HDTV Logo
11,672 people viewed this question
Ekse
