Question about GE (PSS26MSRSS) Side by Side Refrigerator
The green light on ge side by side ice maker keeps flashing
No stuck ice all is clear. Emptied ice bucket and put back in and the green light keeps flashing. Turned it off for a while. It was a steady light for about 20 minutes then it started flahing again.
  • 1 more comment
  • Anonymous Apr 24, 2009
    I have GE side by side refrigerator and the ice maker is not making ice, green light keeps blinking and freezer is not freezing. Also makes a clicking noise.
  • Anonymous May 03, 2009
    Same Problem. Ice maker stopped working. Emptied bucket. Turned green flashing light switch off, then on. Steady green light for a while, and then reverted to flashing. No ice. GE side-by-side, Profile, about two years old.
    Does anyone have a solution?
  • carter6 May 04, 2009
    I am having the EXACT same problem. Ice Maker not making ice. Green light is flashing. I still have water but no ice.
    Can anyone give me any suggestions.
    Thanks
Defrost ligt is blenkin
Posted on Apr 20, 2009
Why is there a flashing green light on the icemaker?
First, pull out the ice bin and eyeball the ice maker device behind it. See if the switch is turned on and the green light is lit. If it's blinking, that indicates "ice stuck in tray" and you'll have to take it out and thaw the whole contraption out. It's not that hard: unplug the giant molex connector on the right side and use a small hex wrench to unscrew the obvious screw holding it to the left side of the freezer wall. Then you can firmly pull the device up and out until it pops free from the notches where it sits in the back.
If there's ice stuck in the device, or if it's just not filling properly, let it sit out for a few hours until it warms up. Depending on the humidity conditions in your freezer, something could have frosted over.Check the swing arm on the bottom of the device. Despite the appearance as a bit of useless plastic, it has a magnet attached to an arm inside the main ice maker housing which allows the maker to tell if the arm is extended or pushed part ways in. Ice being make and pushed into the bucket depresses the swing arm when it falls and the arm returns to the extended position via a small spring mounted between it and the unit unless the ice maker is full. This spring has a habit of popping out of a tiny hole and not providing the force needed for the arm to return to "make more ice" position. Check that it pushes back at you if you depress it.
Hopefully one of these items you've checked wasn't working because they're all easy fixes. Reassemble and add it back to the freezer, making sure that the water dispenser in the back of the freezer leads INTO the ice maker, not BELOW it. This would cause a mess. Make sure the thing is plugged in again, and the green light is back on.
If you're impatient about waiting for another ice cycle to start, depress the swing arm three times in a row. This should tell the ice maker to immediately dispense water and start a new cycle.
Jul 02, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
I have GE Monogram Side by Side. Purchased back in August 2006. It has been pretty good except for the ice maker. After the first year a leak ruined our new wood floors. Recently the ice maker has...
The green light flashing is a fault code, usually for a no, or long fill situation, GE has nixed this electronic ice maker and returned to one that looks similar but is non electronic, while your ice maker is probably at fault you may actually have a separate issue causing the ice maker to display a fault code, such as a spent water filter, or low water pressure, or even a bad water valve on the fridge it's self. IM6 is the current replacement ice maker kit for previous ice makers. Pleazer Appliance...
Apr 17, 2014 | GE Monogram Side by Side Refrigerator
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
if there is ice in the mold then the problem is the ice maker unit , replace the ice maker for the fix.
Phil
Jun 10, 2009 | KitchenAid KSRG25FKSS Side by Side...
Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker does not make any ice green light flashing in freezer
There was a small piece of ice stuck in the back prongs. Removed stuck ice (very small but enough not to make it work). Now it works GREAT!
May 15, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker not working flashing green
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dfdf
Jul 28, 2008 | GE PSS29NHP Side by Side Refrigerator
General electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
Jul 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSS25LGM Ice maker
one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
807 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
