Washing machine pump is leaking - Washing Machines
    Genius:
  • 1,122 Answers
What make is it ?is it a top load?mike
Posted on Apr 20, 2009
My Kleenmaid washing machine leaks Crease during whashing.
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 27, 2013 | Washing Machines
Front load washing machine leaked when not in use
Jan 23, 2013 | Washing Machines
The smart drive washing machine leaks when in use what can I do? Thanks
if it is leaking from bottom check pump if it looks like rusty looking then its been leaking for a while replace pump if you keep operating washer with it leaking from pump it can also short out control board
May 13, 2011 | Fisher and Paykel Washing Machines
Washer leakes from front
Good Afternoon, Jataw42:
A leak from the front means a problem at the pump, or in the attached hoses.  A large leak means a hose has to be replaced, and a small leak means the pump has to be replaced.
Both are simple fixes, and these guys have everything you need.  Here are the parts:
#904568 for the drain hose from the pump  and #1304058 from the tub to the pump.
These are here:  http://www.repairclinic.com/Kenmore-Washing-Machine-Hose-Tube-Or-Fittings-Parts?s=b6a11c23p
The pump can be found here:
http://www.repairclinic.com/Kenmore-Washing-Machine-Pump-Parts
and the video instructions are great.
Good Luck to you!
Chr
Jan 22, 2011 | Kenmore 22422 Top Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Roper RAX7245KQ0 Problem: Washing Machine Leaking Water
This is the best designed life long lasting Whirlpool washing machine. This core design is more than 35 years old and it is so good Made in USA design. Cannot go wrong.... Coming from 1969 Moon landing time where Made in USA matters....
Most of the time in this design, the drain pump leaks. Is the leak is coming from front middle. It might be the drain pump. Careful observation is needed. Check the drain pump seam for possible water marks or brown color water marks. Make sure before changing.
Make sure it is the drain pump. Can be something else too.
Part description for water pump for your model with a video clip how to change it.
https://www.repairclinic.com/PartDetail/Drain-Pump/WP3363394/3296?modelNumber=RAX7245KQ0
Oct 09, 2017 | Whirlpool Washing Machines
Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Jun 07, 2009 | Maytag Neptune MAH6500A Front Load Washer
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine leakes some where frome the bottom of washer
It sounds like you pump is leaking. This happens most of the time( if its a kenmore or whilpool)lean your washer back and then you will see the pump on the end of the motor. it is held on by 2 clips and then you can take it off (after pulling iff the 2 water hoses) Look at where the motor shaft goes onto the pump if its leaking there will be a water streak. Replace the pump... leak is fixed
Oct 28, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
