Question about OKI C5500n Printer
OKI c5600 drum reset
How to make a drum reset and toner reset?
Printer OKI c5600
It is posible to mak it ?
  • Anonymous Mar 18, 2014
    My oki c5600 tells me to replace the image drum 562:K Drum Life. what do we have to do? buy a new cartidge?? thanks for your help.
  • Anonymous Mar 28, 2014
    After I accidentally did Flash Format, the Network Menu is gone. May I know how to restore the Network Menu? Many thanks.
  • 628 Answers
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Posted on Apr 20, 2009
Oki b431 DRUM reset
hello good afternoon, friend u can give a hint of how I resouvo the problem of drum printer oki 431dn + b, pending
Jul 05, 2012 | Oki Electric Industry B431d Printer
Strange clicking noise OKI C5600
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
Jun 02, 2010 | OKI C5400 Laser Printer
K drum life keeps coming up,
The best is to replace the black drum, you can fix it but you have to take apart, clean out the waste toner, replace the fuse, and cleaning blade and reassemble. The fuse will reset the printer to know it's a new drum.
Dec 23, 2009 | OKI C5200n Laser Printer
OKI C5600 error code 411 says toner cartridge is empty (isn't)
Kedves Mindnyájatok!
AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van.
Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására?
További Szép estét kívánok!
Lacika
Oct 26, 2009 | OKI C5650n LED Laser Printer
OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
Specks of blue on my printing.
Replace the cyan drum unit. If the specks are always in the same line there is small ding in the drum. If the specks are random then the cleaning blade inside the drum unit is bad. When ever the defect is just one color it usually is that color drum unit.
Apr 15, 2009 | Office Equipment & Supplies
On Oki C5600 printer with error message " Order k drum" and does not let me print. Can any one help how to reset and clear this message?
Try this procedure, don't know if it will work on your models.
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
Apr 12, 2009 | OKI C5500n Printer
OKI B6300 Drum problem
Hello, com_jedi. I would suggest you contact the OKI Customer Support line in order to address this issue. The phone number is 1-800-654-3282 (800-OKIDATA). For your model unit you would hit options 1 then 4 to get to mono support.
It is possible that you purchased a defective consumable and OKI warranties them for 90 after the date of purchase. If this is a new drum/toner it may need to be replaced to determine if it was a bad chip in the cartridge or if there is some other issue with the unit that is causing the error.
It is also possible there is a misalignment with the sensor that is located under the drum unit. A support tech can walk you through the troublehshooting as it would be a bit difficult to do here.
I hope this helps!
Feb 12, 2009 | OKI B6300 Laser Printer
Toner warning
THE TONER CONTAIN NEED TO BE WASHED OUT WITH SPECAL CHEMICALS, PRINTS NEED MAINTNANCE, OVER FLOW CONTAINER MAY HAVE TO BE EMPTYED ALL SO, CORRORNA WIRES NEED TO BE CLEANED
DRUM MAY MAY NEED SERVICE ALSO
ROD
Feb 03, 2009 | OKI C5200n Laser Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
OKI C5500n Printer Logo
5,766 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
SiNnA
SiNnA
Level 1 Expert
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
