Question about Lucent AT&T 960 Corded Phone
Need manual I need the manual for this phone. Speaker phone button doesn't work. Need to know how to program speed dials. thanks.
    Habit-Forming:
  • 68 Answers
Given that consumer telephones are inexpensive, the cost of repairing the speaker phone on the 960 (assuming you still have it) is probably not worth it.
Going off of my memory....to program a speed dial you would first press "Program", enter the telephone number you want stored and then press the one of the memory buttons to save the number to. If the number is to be saved on a lower memory position press "Lower" before you press the memory button.
AT&T's telephone product website has a section where user manuals for many AT&T and Lucent branded telephones.
http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm
The 960 is no longer listed, but the many of the basic functions are similar to the 922.
Posted on Oct 29, 2008
2 Suggested Answers
SOURCE:
bestdarngood
  • 3037 Answers
SOURCE: DTP-HHM-2 speed dial buttons
Main support number 1-800-338-9549, I'm sure they can help you
Posted on Mar 19, 2008
Hello, please i want to know how to set up speed dial on the KXT7730 that is not the main line ie not on 0, or 101 on the switch board
Guessing that you already know about SYSTEM speed dials, then the 12 buttons on the right side of your phone are the PERSONAL speed dials. When you get dial tone on the intercom, you can dial "9" and the system will either give you a dial tone, or the highest line in the system. If that is not a working line, you need to fix that first (system program 400 assigns lines in service).
Once you have that, a PF button is programmed by pressing PROGRAM, the button, and dial 9 + your number dialed the same way as if you had pressed a CO button then STORE. You can keep pressing PF buttons and programming numbers. Then press PROGRAM or pick up the handset and drop it back down to end programming.
Carl
Apr 21, 2011 | Panasonic KX-T7730 Corded Phone
I have a NEC Dterm Series II phone. I need to
This phone works on different NEC phone systems.Elite,IPK, 2000, 2400. Each speed dial code is different in each system. what system do you have
Jan 05, 2010 | NEC Dterm DTP-2DT-1 Phone
I have a toshiba DKT3512S and need to reset the time, also i would like to know how to do speed dials. Thanks mara
You will have to get into program mode for this. you will have to press this sequence of buttons. Hold*#*#1*2*3*. Password is default to 0000. Program number is 902 then press hold. Press Intercom button for Date and line 1 button for time. If you press Intercom #66 enter speed dial number 10-99 is station speed dial. If you press Intercom #66 and enter speed dial numbers 100-999 will be system speed dial. Hope this helps. I included a site below with program manuals.
http://www.wedophones.com/ToshibaManualsLead.htm
Oct 12, 2009 | Toshiba DKT 3010 Corded Phone
I have an older at&t 620 speaker phone
goto call settings and fix in the numbers you want for speed dial
Jul 15, 2009 | Lands Phones
Set speed dial
This may or may not work as my manuals are for the 9xx series but not the 950. Press PROGRAM
to erase press PAUSE and either the BUTTON or LOWER BUTTON (2 keys).
To store a new number, PROGRAM then dial the number you want saved (or press REDIAL) then the BUTTON or (LOWER BUTTON).
I'm guessing this will work, since the other models seem to program the same way.
Carl
Feb 27, 2009 | AT&T 950 Corded Phone
Euro style 18d how to program memory keys
The Avaya website (www.avaya.com) is loaded with manuals, you just have to know where to look.. Here's one http://support.avaya.com/elmodocs2/partner_acs/r7/518457701_2.pdf
Page 13 tells you how to program a button (ie FEAT 00 button dial the number and press FEAT 00 again to exit). Page 16 tells you how to program personal speed dial number from the 20 bins 80-99 allotted to your phone.
Carl
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
Emmerson Phone Manual EM2248
Emerson (EMSEM2646WH) I need to know how I can set up the speaker phone and in a way that will be clear and loud. I lost my manual, could you send another one to me?
thanks
Nov 05, 2007 | Emerson EMSEM2646WH Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
Lucent AT&T 960 Corded Phone Logo
850 people viewed this question
Top Lucent Lands Phones Experts
Ekse
socrtwo
Level 1 Expert
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
