Question about iLO (2 GB) MP3 Player
I have 32gb pen drive but it's protected. so help me how would i unprotect it.
  • Anonymous May 15, 2009
    my pendrive displays write protected when it fills after 4gbs
    President:
  • 281 Answers
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 08, 2010
  • 51 Answers
Try to format yout pendrive in ntfs partition and if the problem still persists.then format with the http://dl.dropbox.com/u/4040651/LLFTOOL.EXE tool..if you are unable to format (low level) then its due to some hardware faults..better throw it away or try to satisfy with tht 4gb..!!
Posted on Feb 09, 2010
My 32GB USB Drive needs formatting but when I try it says that it is write protected. How do I remove the write protect?
Follow the steps to remove the write protection from the pen drive:
1. Open the Windows Registry Error by pressing a shortcut Windows-r
2. Type regedit into the form and press the return key on the keyboard.
3. Navigate to the following Registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
4.Double click the key Write Protect in the right pane and set the value to 0 In the Value Data Box. Press OK
5. Exit Registry
6. Restart your computer and re-connect your USB pen drive on your computer.
Mar 05, 2013 | Computers & Internet
I have a 126gb Kingston pen drive which states it is write protected when I wish to delete files. How do I unprotect the drive?
try to scan your pen drive in updated virus scanner then try to delete files .because infected files are hard to delete.
May 16, 2011 | Kingston (S40J107) Hard Drive
I have one 32GB Kingstone Pendrive & I have store on a data of above 1 gb but When It reconnect to PC it's show the only empty folder, so please send me solution of the same...
It’s difficult to give you an exact fix without having your pen drive in hand and at a computer, but I will give you some things to check for:
1) Does the pen drive have a read – write protection enabled? If so turn it off.
2) Make sure your windows explore has the folder view options set so that you cans see file extensions. This will definitely come in to play if the files on your pen drive are not common files. e.g. (ms word)
3) No the bad news!!! There are many reports of the 32GB Kingstone pen drive being FAKE. If you do a google search you will see many consumer complaints.
Respectfully,
David
fix4mypc
Aug 07, 2010 | Computers & Internet
How to done unproctet my pen drive:- my pen drive is show that is protected and i can not don any thing with it like copy,pest, rename etc... i have no option to resolve this problem now
Hi ramsaini59
On some models of pen drive there is a switch on the side to protect or unprotect the drive.
If yours does not have one then you may not have permission to write to removable media. This could be either through the operating system or a third party software.
Does this help?
May 07, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive write protected
I have had the same prob and able to remove the write protected message by just unlocking the hold button. If this doesn't work there is formating software for each USB on the web. One can google and download it for free inorder to formate the USB
Aug 11, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Write protected pendrive
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Jul 15, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
How to Unprotect a Write Protect Flash Drive
how to unprotect a write protect my flash drive & i cant copy paste any of my files to my flash drive it gives an error
error drive not found
Oct 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PQI 2G Intelligent Stick
First double check the stick for a tab with a picture of a lock on it, if that is there then switch it to the other position, if your drive lacks the switch then connect the drive. Go to my computer, right click the drive, click properties and search the taps for write protection and disable it(im sorry but i forget what tap it is under) hope that will help you out some but let me know if neither of those help
Dec 10, 2007 | PQI 512MB Intelligent Stick USB 2.0 Flash...
iLO (2 GB) MP3 Player Logo
181 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
