Question about Whirlpool Calypso GVW9959K Top Load Washer
My Calypso washer and dryer will not power up.
Had a power-loss in my home on Easter Sunday. Two days after electrician restored power, washer and dryer will not come. Note, when opening the side door for dryer load interior light goes on.
  • 1 more comment
  • mel_park Apr 20, 2009
    that's correct there are no codes displaying on my washer. I just replugged and still nothing. So, do you I have same problem with my dryer too?
    after a recent power surge in my home I noticed both my whirlpool (Calypso) washer and dryer are working. I have checked the power to each and all is well. There are no codes displaying either. The dryer has power the drum inside light illuminates. Both units will not activate. Help!
  • mel_park Apr 21, 2009
    awaiting electrician to arrive today 21 apr 2009
  • 315 Answers
There is definately some issue with the Power Supply on those two power socket..... call any electrician and ask him to check the voltage on both of your socket(socket of washer and dryer) with he help of Multimeter..
Posted on Apr 20, 2009
  • mithun dey
    mithun dey Apr 21, 2009
    Have you checked the voltage you are getting.... as it seems that you are getting proper voltage on those sockets
  • Whirlpool Master
  • 19,396 Answers
Try first unplugging the appliance for ten minutes.
If this does not fix the problem, try with the clear/cancel/exit button.
If still no luck , and there is no error code flashing, then the timer board may have been damaged by the power surge.
PF ERROR
Had same problem with my ex-wifes drier. If possible load test your wall outlet. Chaces are one side of the breaker is not putting out what it should.240 total 120vac each leg.
Oct 03, 2017 | Kenmore 659 Electric Dryer
Whirlpool calypso washer smells how to get rid of ordor
Removes odor causing residue in front loading (HE) washers. Keeps your machine fresh and clean. Package includes 3 tablets. For front load washers only.
Here is what you need.
Oct 18, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Is it safe to use a 3 prong dryer cord on my 2004 Kenmore Calypso dryer? I moved to an older home with a 3prong outlet.
It is safe as long as it is wired correctly. The following link explains the differences between 3 and 4 prong configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Just make sure to match the corresponsing wire colors at the terminal block in the back of the dryer:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - Ground
In a 3 wire configuration the Neutral (White) and Ground (Green) wires are terminated together at the terminal block.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
The other alternative is to have an electrician install a 4-wire receptacle in your home.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 31, 2010 | Kenmore Elite HE4 Electric Dryer
My Calypso washing machine doesn't allow you to select start. It is an intermittent problem which seems to clear itself after a couple of hours. How do I fix it?
Hi , I,m online now trying to fix my calypso dryer problem , ijust got done fixing my washer 10 minutes ago (clogged pump) . In the past I have unplugged the units when they acted up (re-boot) and worked up til this sunday . Good luck !!
Rob
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We went camping for 2 days came home and the calypso washing machine won't start. We ran a load the day we left with no problems. The outlet works fine, we even tried plugging it into another outlet just...
The same happened with my Sears Calypso machine. The common problem is the front display panel. If you are able to find one at a very good price, post it here.
Aug 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Delayed preview image
Sounds like you accidentally pressed the DISP button on the back (it manually turns the LCD screen on and off to save batteries). Turn the camera on and press the DISP button once. Hopefully that should fix it.
Mar 24, 2008 | Canon PowerShot A550 Digital Camera
Whirlpool Calypso GVW9959K Top Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal De
