Question about Canon PIXMA iP1700 InkJet Photo Printer
Canon pixma ip1700...cartridge cannot be recognized
My cartridge cannot be recognized even already try to install it many times...
how to solve it..?
  • Bob Kitaji May 11, 2010
    Is it an OEM or refilled cartridge.
  • 4 Answers
Do a temporary reset. u can found it how to do it.
temporary reset is a procedure before doing a permanen reset (usualy with resetter software)
temporary reset is bypass ur cartridge recognition
here it is :
1. turn off ur printer
2. pull off all cable that connect to printer (2 cable, usb and power cable)
3. press and hold the power button, then insert the power cable (still hold the power button)
4. while u still hold the power button, press the resume buton twice. the release them both.
5. because its a temporary reset. u must do it again if u lost electricity power.
met coba :D
Posted on Jun 03, 2009
My new pixma canon ip 2770 cannot recognize the black and colored ink
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Printer Canon iP1700 - I have already put the new inkcartridge black & colour but the printer says inkcartridge colour is not installed properly. I have installed so many times but same problem.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Jan 03, 2011 | Canon PIXMA iP1700 InkJet Photo Printer
THE INK ABSORVER IS FULL
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Step 2 : Using software resetter
  1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
  2. Ekstrak/Unrar/Unzip the Software
  3. run GeneralTool.exe
  4. Select USB Port where the canon ip1300 or canon ip1700 installed.
  5. CLick Lock Release button
  6. Select EEPROM CLEAR
  7. Click Test Pattern 1 button
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
Resetting Ink-Waste Ov
Nov 27, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
My Canon IP 1800 cannot recognized the Black ink
It sounds like the electrics on the back of the cartridge have failed, replace with a new cartridge, and away you go.
Jun 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
An Ink cartridge is not installed properly and the ink cartridge cannot be recognized
buy 1liter of gasoline and pour it on your IP1300 and then fire it up... I have the same problem and I already solved it! Canon is wasted!!! Just buy other brand.
Apr 21, 2009 | Canon PIXMA iP1300 Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
INSTALLATION OF CANON IP1700 PRINTER
I dont have a cd to install my Canon pixma iP1700 printer. Can u please help me. Thanks
iP1700
Aug 10, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Open Questions:
See all Canon PIXMA iP1700 InkJet Photo Printer Questions
Canon PIXMA iP1700 InkJet Photo Printer Logo
1,700 people viewed this question
old marine
old marine
