The service manual will only cover disassembly. Acer technicians only swap out parts. Acer do not release the circuit diagrams to anyone. Fixing laptops on a component level is a case of knowing how a laptop works and being able to diagnose the problem yourself, unfortunately.
If you still want the manual, it is available here:
http://bertrand.ep.free.fr/Ferrari3200sg.pdf
Does this happen if you take the battery out and run on mains only? Or do you not get the light at all. If you don't get the light, it could be that your system is telling you the battery is dead, and it isn't charging. Check the PSU is giving out the correct voltage, check the socket is making contact, then check the charging circuit.
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
