Question about Epson TM-U295 Matrix Printer
Problems with Epson TM-U295 Matrix Printer release light flashing and not printing. Please send me a solution.
3 Suggested Answers
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
  • 415 Answers
SOURCE: Epson TM-U295 Matrix Printer light printing
You need to adjust the print head spacing. This is a lever along the side inside the printer by the print head. It just move the head closer or further away from the paper. The closer it is the harder it strikes the bottom pages and it should print darker on them. If you get it too close it can catch the paper and cause a jam so you have to give it a bit more space. You may end up redoing this if you use a different brand or type of nc form paper. Just open the cover look for a lever on the side and lick it a notch (should show circles so go to the smaller one) and try printing. You might have to waster a few pages before it behaves but this is all you need to do.
Posted on Sep 02, 2011
Epson TM-U295 Matrix Printer light printing problems The paper i use is 3 sheets, 1 original and 2 copies, the copies no longer print clear, i have tried changing the ribbon but this only improves the...
Sep 02, 2011 | Epson TM-U295 Matrix Printer
Epson TMU-295 prints in condensed mode with Windows 7 from web application while the same printer prints the same output in normal mode with Windows XP. How comes?
window is not the faulty one if you are using a third party software of sent print option from internet then problem must be with in drivers..... print a self test page if ok then print test page from system (control Panel) if both point ok then there must be problem in online software/ERP.
Aug 11, 2011 | Epson TM-U295 Matrix Printer
Only 8 lines are priting
You will need to install the correct diver for the printer for it to recognize the capabilities it has. Some require the page break for the seams to be set. Some printers have a mark to put the page break on when loading the paper. The printer may not be set for "continuous paper feed" and only printing a single page according to where it thinks the page break is.
Mar 06, 2011 | Epson TM-U295 Matrix Printer
Epson TM-U220 not working with window 7
download this driver APD-406aE i did it and it is working perfect with my windows 7 on a TM-U 220B
Jul 07, 2010 | Epson TM-U220 Matrix Printer
Epson printer just printing question marks
It sounds like it could be a driver problem, try downloading the latest printer driver for your printer from http://www.epson.co.uk/jsps/searchResults/layouts/landingPage.jsp?userQuestion=TM+U210D&_dyncharset=UTF-8&_requestid=391173
If this has helped you then please rate me!
Aug 23, 2009 | Epson TM U210D Matrix Printer
Tm-u295 firmware problem?
I can solve that problem but i need some help in the firmware of TM U220B. I just need the .bin files to downgrade to version 1.02
Feb 18, 2009 | Epson TM-U295 Matrix Printer
Epson TM on Windows XP with serial
you need to use the printer cable that was design for the printer. if you don't have the cable anymore, then you have to take the commercial cable apart and reconfigure in accordance to page 43 of the manual call outs.
Besides the cable, the printer software is only good for Windows 2000. Windows XP will not work unless Epson provide you with the printer driver. (which I did not see on the website).
all in all if you must use this printer with Windows Xp. you need to create a file in Autoexec.bat to enable the printer and allow the USB to connect to the printer.
that is going take time to do. if you need help on that. please post the request here.
Thanks
Dec 03, 2008 | Office Equipment & Supplies
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Installer Problem
please go the www.driverguide.com
and install the driver
Mar 28, 2008 | Epson TM-U295 Matrix Printer
Printing
You mean you want to see or put a page number on the document you're printing?
Feb 26, 2008 | Epson TM-U295 Matrix Printer
Epson TM-U295 Matrix Printer Logo
538 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
