Question about Panasonic PT-51G54 51" Rear Projection Television
Samsung SP-43T6HP rear projection TV 42" picture problem
Can any tell me what they think is wrong with my TV. It has split into 2 pictures, the 2nd being a blue shadow like one on the right of the main picture. Do I need to call someone to come repair it for me or can I do it myself? Thank you
Kelly
  • zaenalari864
    zaenalari864 Jan 22, 2013
    TIDAK TAU NO SERI SPAREPART
snakehead
  • 1074 Answers
SOURCE: Red Shadow on scheen
your tv needs to be align take it to a tech so that the tv can get a convergence adjustment it is call color bleeding.these things when a set gets old this wil cost between 440.00 TO $75.00,in this the comb filter and the screen voltage will be checked.
Posted on Mar 30, 2007
  • 133 Answers
SOURCE: Panasonic Rear Projection TV - PT-47WXC43G Convergence Problem
The tube should be ok its the IC's regulating the convergence is your problem . A tv repairman should be able to repair it fro around $250.00 - $300.00 or less depending on who you call. Good luck
Posted on Mar 01, 2008
pazman
  • 81 Answers
SOURCE: i have no picture panasonic xf series model no. 56wxf95a
lamp bulb
Posted on Apr 16, 2008
  • 1894 Answers
SOURCE: Samsung 105" RP have to
do you mean that the setitngs are not getting saved eac time you set it?
am i right.?
Posted on Jul 08, 2008
  • 41 Answers
SOURCE: convergence chip
Convergence ICs cost around 15-25 each there are only two of them. I would go ahead and replace both of them because if one goes the other one will follow shortly. I would make sure that it is just the convergence IC not something else, and if its over five years old dont pay more than $500.
Posted on Oct 07, 2008
Ihi i have a samsung sp 43t6hp and it looks like im watching tv in 3d how could i fix the problem
Sounds like you need a convergence board. Problem is there might be some transistors that you need as well. I've had a similar issue. Most places will cost $300+ to replace what might be a $15 part. Also there are 2 transistors in there that need to be replaced at the same time (once one goes the other is likely to as well). I would suggest calling Sears to fix it. They charge much less for the visit ($99 min charge) and will replace both parts at the same time.
Sorry I know that's not a true answer on how to replace the convergence board or other parts but mucking around in a rear project tv is a good way to get shocked. Those TV's hold a lot of charge even after unplugging.
http://www.searshomeservices.com/televisions/repair
Mar 03, 2011 | Samsung HCL652W 65" Rear Projection...
I have a samsung hls6186 rear projection tv and it comes on and the picture is fine and about a minute later it goes off and three lights in the front are blinking. how can i tell whats wrong
I had the same issue, I purchased a new lamp, installed it in 2 minutes. The picture is like when I first purchased the tv. You can find the lamp code sticker on the left when facing the tv.
Feb 27, 2011 | Samsung HLS6186 Television
I have a SP-47Q7HE Samsung rear projection TV that has 3 pictures that are not aligned. Top and bottom of screen distorted concave and convex?? Any advice appreciated
You need to replace your STK ICs they are big black ics will have part number on them you also need to CK 2 reisitors low ohms in same circuit 2.7ohms Mats has the ICs 9.95-14.95 each.
1-800-628-1118.
Encompass Parts Distribution you can order the whole board if they still have any in stock visit their website and type in your model number or call 1-800-638-3328
Jul 16, 2010 | Samsung HCM4215W 42" Rear Projection...
My screen color looks like the green and the red are split.
U hear grinding,squiling,motor noises,picture flicker black&white?This tv have a colors wheel.The problems u describing sound like the colors wheel it not functions correctly any more.
Jul 16, 2010 | Samsung HC-P4752W 47" Rear Projection...
Picture has blue at the bottom and yellow at the top. Double images and the station logo is in the wrong place
This tv have convergence problems.Tries website Tvrepairworld.com to buy the whole refurbish convergence board for the replacement.The Samsung/Akai used the same convergence board.
May 15, 2010 | Samsung HCN4226W 42" Rear Projection...
I have a samsung 42 picture lines top and bottom of screen
DAve1645 is correct!
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 28, 2009 | Samsung HCM4215W 42" Rear Projection...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Panasonic PT-51G54 51" Rear Projection Television Logo
446 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
