Question about Toshiba Satellite A85-S107 Notebook
Want to reset my bios setup password for my A85 toshiba laptop. Which jumper need to be reset
  • 75 Answers
You need to open the back cover of your laptop so that you can access the motherbaorad..ther u can see  a CMOS battery ..just remove it and after 20 sec ..put it back..it will reset th BIOS password...
Posted on May 11, 2009
  • stacynicole3 Aug 11, 2011
    the battery is soilder into the motherboard, so you can't take it out without having to soilder it back in, I am having the same problem and need the location of the jumoer pins.
It barely flashes TOSHIBA then goes to a password entry that I don't know
Most probably a password has been setup in BIOS to prevent unauthoirsed use.
You need the password, or you need to reset the BIOS. This is difficult in laptops as the case is hard to get into.
Also generally the battery needs to be removed/replaced in laptops, rather than opening and closing a jumper, as in a desktop pc.
Apr 05, 2015 | Toshiba 14.0" L745-s4235 Satellite Led...
My laptop is asking for PhoenixBIOS Setup Utility password. Can you please help me out with da password?
tRY THIS LIST AND OTHER ALTERNATIVES THAT FOLLOW...GOOD LUCK
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords.
Award BIOS backdoor passwords:ALFAROME BIOSTAR KDD ZAAADA
ALLy CONCAT Lkwpeter ZBAAACA
aLLy CONDO LKWPETER ZJAAADC
aLLY Condo PINT 01322222
ALLY d8on pint 589589
aPAf djonet SER 589721
_award HLT SKY_FOX 595595
AWARD_SW J64 SYXZ 598598
AWARD?SW J256 syxz
AWARD SW J262 shift + syxz
AWARD PW j332 TTPTHA
AWKWARD j322
awkward
AMI BIOS Backdoor Passwords:AMI BIOS PASSWORD HEWITT RAND
AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords:phoenix PHOENIX CMOS BIOS
Misc. Common PasswordsALFAROME BIOSTAR biostar biosstar
CMOS cmos LKWPETER lkwpeter
setup SETUP Syxz Wodj
Other BIOS Passwords by ManufacturerManufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM Aptiva BIOS
Press both mouse buttons repeatedly during the boot
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system.
ALSO, HIREN'S BOOT CD HAS SOME BIOS PASSWORD CRACKERS ON IT IF THIS DOESN'T WORK.
Oct 21, 2010 | Toshiba Computers & Internet
Don't know BIOS password
Here's how to reset password
Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptops can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Jul 25, 2010 | Toshiba Satellite A105 Notebook
Toshiba Satalite A215 Laptop Bios Password
remove battery.....wait for 3 minutes....put it back and turn on...the bios wii get reset.....
if it still didnt got reset, then you need to remove cmos battery in the board by removing the back cover....
Apr 20, 2010 | Computers & Internet
Toshiba bios setup password
To remove the bios password you need to clear the CMOS.
Open your laptop casing look at your motherboard. locate the CMOS jamper it is near the battery. To clear remove the jamper and turn your computer on with in 5 to 10 seconds and turn it off. Reinsert the jamper back to there proper place and try to turn go to BIOS if there will be a password box appear.
You need to open your laptop and look at the motherboard and locate the CMOS battery. Just remove it with in 5 minutes to clear BIOS password.
Apr 18, 2010 | Dell XPS M1210 Notebook
How to Break BIOS Setup Password
there is no way to break that password..the only way to remove it is to reset the bios by short the clear bios pins(jumpers)..or remove the bios battery ..this will erase any settings and when you put the battery back will be on optimal factory defaults..(same if you locate the jumpers for clr Bios) but ..for that you have to open the laptop ...its easier for desktops..but for this will be a little much ..but is the only way ...so ..in short be careful and you have to get to the motherboard and remove the battery ...if you do not have an acces point to the jumpers..
Mar 26, 2010 | Toshiba Satellite 5105-S501 Notebook
Tecra , laptop bios password needs to be reset.
mera laptop
think pad r40e
bios pass word
my bhool gaya
pls mere ku help karo
Feb 17, 2010 | Toshiba Computers & Internet
I need to remove the bios password for toshiba Satellite A85-S107
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
Oct 18, 2009 | Toshiba Satellite A85-S107 Notebook
Satellite A215-S7416 Bios Password
There is a jumper that will clear the BIOS password on most of the newer Toshiba laptops such as this model. Here is a link to an article showing where the jumpers are located on various models of Toshiba laptops.
http://www.ccl-la.com/blog/index.php/clearing-bios-power-on-passwords-on-toshiba-laptops/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 17, 2008 | Acer Aspire 3680 Laptop
Problems with my Toshiba Laptop.. A85-S107
I think it is not a problem. You can find a battery inside of the laptop. Get it out and make it converted in the battery slot to clean the COMS. Then your laptop will be fine.
Jul 31, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 Notebook Logo
542 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
