Cannot load program using windows xp
Cannot load turbocad v3.0 using windows xp
  • 37 Answers
If reinstalling doesn't work then i suggest trying these 2 similar free software.click first link to register for serial number and then download from the 2nd link. you might find these better.
http://www.conceptdraw.com/registration/cd7special.php?iml_uk
http://download.cnet.com/ConceptDraw/3000-2191_4-10367699.html
http://www.brothersoft.com/doublecad-xt-231767.html
Posted on Jul 27, 2009
I have now got a new commputer and although I have been using turbocad for a lot of years on my old computers I can't get the 'measurement' part of the tools button to work now. I no longer...
Hi ralph81
The problem is that you are now running a Windows 7 64-bit system on your computer and your product dosen't seem to be compatible to it .
A solution could be a workaround : install a virtual version of Windows XP on your system . You ' re welcome back if you need further assistance or information . Just add a comment below .
Best regards ,
fanaudi .
May 22, 2011 | IMSI TurboCAD Standard 8 Full Version for...
Turbocad starts to register regenmethods from tcimage.dll
Re: 11.2 Program will not start
I found this on the TurboCAD forums,
"Doesn't appear in "Applications" but appears in "Processes" in Task
Manager (XP)."
I posted the following there also.
I am having the same problem sort of. I installed it on my computer
and the TCStart Module stops responding.
If I click the TC icon, the TCStart Module will open, but if I click
on "NEW" it just closes and stops responding.
I tried opening a file that I had brought home on a disc, clicked on
it, and it will not open.
If I try to open the file from the Start Module by navigating to the
file location, the whole thing stops repsonding.
[EDIT]
One more thing, at the bottom of the Start Module it says, "TurboCAD
starts to register RegenMethods from TCimages.dll...", and it stops
there. I don't ever remember seeing that before.
[/EDIT]
Mar 02, 2011 | IMSI TurboCAD Deluxe 14 (Win) Full Version...
My husband had his computer fixed and installed his turbocad 9 and it will not open because it says 0 days left to register
it seems your program needs to register cause its a trial version..go to site of your software and register
Feb 10, 2011 | IMSI TurboCAD Professional 9...
Virus
Restart your computer and before it says "Starting Windows" (XP, Vista or whichever version you have), press the F8 function key on your keyboard. You'd get a menu. Select the "Safe Mode with Networking" and press Enter.
Once Windows boots into safe mode, try to run the programs now. If they run fine in safe mode, download Malwarebytes .
Then, update and run this anti-malware program. It will remove any virus / malware. Once this is done, reboot your computer back normally and the programs should work fine.
Hope that helps,
Regards,
Raspal
Mar 25, 2010 | IMSI TurboCAD Deluxe 10 for PC
I have four floor plan files made with Turbocad V6. When I try to run them to get a print I am greeted with the message "Failed to open;? Loading Header." I am running Windows XP Pro SRP3. Other files...
the issue is that you probably saved the files into a format that the computer u use now is unable to open and read ...so ..the thing to do is make sure you have the program they were saved in ...and gave the print command from that program ..the one that the files was saved from
if you do not have them into this computer ..install it ...or see the file type on the properties...and look on the net for a reader for that type ...or let me know the format that they were saved ...to look for a program that will read them ....also check to be sure they are saved correctly
Nov 09, 2009 | Computers & Internet
Downgrading from Vista Business to XP Pro
Why dont you give Windows 7 a whirl. Im running it and so far i like it better than xp and it stomps vista into the ground.
If your wanting to downgrade to Windows XP pro, Your going to need to reformat the PC. Simply put the media in the drive restart the computer and boot off the CD-Rom and follow the simple instructions.
May 21, 2009 | IMSI TurboCAD Deluxe 10 for PC
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
Vista with turbocad
Hello Robinmia, When it comes tp a production environment, the owners are right. Productity is the most important. Check the website support for Turbocad v9 for the patch. If none Windows Xp should be loaded.
Apr 15, 2008 | Microsoft Windows Vista Ultimate Edition
Turbocad V10.2 will not work with Windows Vista basic
well, turbocad deluxe 10 is NOT compatible with vista. Here is the compatibility list : Windows 98/Me/NT4/2000/XP Pentium-class PC 64 MB RAM (128 MB recommended) 55-212+ MB hard-disk space 64 MB of swap space Super VGA (1024 x 768) display High Color (16 bit) graphics card 4x CD-ROM drive with 32 bit drivers
Jul 16, 2007 | IMSI TurboCAD Deluxe 10 for PC
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
