-   Mine has the same problem. When it get to 66 minutes left on the Heavy cycle it stops and then clicks every few seconds. It has water in the bottom also. Any suggestions?-   temom
Jan 23, 2009
-   i have same problem when i took it apart without this one plastic part it worked put when i put the plastic part back on it will cut off and try again and again to drain-   michael71591
Jul 07, 2008
-   Same problem. Any solutions out there?
-   kentb
I had the exact same problem. When the service tech came to look, my husband watched him. There was a disconnected wire to the motherboard which my husband asked can't the tech just reconnect it. The tech stated no, we needed a new motherboard. My husband reconnected the wire using tape for now & the dishwasher is working perfect. My husband is going to get somekind of calk/glue that will work permanently. This should save us from replacing the motherboard for a while. The dishwasher is only about 5 years old! My previous dishwasher was over 20 years old with no repair problems the over 10 years that I owned & used it.
I am looking for the self check test, does anyone know where I can find the instructions how to do it myself? Thank you
If it is a wire disconnected to the motherboard all you need to do is solder it back on. You need a solder GUN, not a solder stick. Use solder with resin already in it.
Only do this if you are good with a soldering gun, as if you get too much solder on you will destroy your motherboard.
Was this helpful?
Yes
No
Solution #3
posted on Aug 14, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you need a new mother board, mine did the VERY same thing and now works fine
the spray arm has come away from its vertical installation position, it does not look as if anything...
(More)
the spray arm has come away from its vertical installation position, it does not look as if anything has broken off but i cannot seen to reattach it, can anyone help
THE DISHWATER FILLS WITH WATER. ATTEMPTS TO DRAIN STOPS AT 2, THE MAKES A SOUND EVERY FEW SECONDS, WITHOUT DRAINING.I WAS TOLD BY A SEARS TECH THAT THE FLOATER IS BROKEN,AND ELECTRONIC BOARD IS BURNT OUT. BOTH NEED REPLACING FOR OVER $250. I'M SCEPTICAL
After filling with water, my Maytag jetclean EQ plus just makes a clicking noise. After a few minutes of the clicking noise, the lightwash and clean button are flashing red. I need help? We have not had the dishwasher that long. I thought Maytags last for many many years. A busy Mom of three.
