Question about Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246)
Delay in aquiring IP Address
I am using an Intellinet model 523455 wireless router which is connected to my desktop and a wireless connection to a small network of 2 laptops. Since of late my desk top takes about 30 min to login as it has limited or no connectivity. pressing the repair button does not have any effect
2 Suggested Answers
SOURCE: Wireless connection
I finally hit it. I tried dial up and LAN and same fault. Turned out that somehow, through our protection software, internet traffic was halted. Just needed to open it back up.
Thank you all for your suggestions.
Posted on Oct 22, 2007
HELLO.I HAVE A SATELLITE INTERNET CONNECTION TOOWAY WITH MODEM RM 4100 VIA SAT.AND I WANT TO MAKE THIS WI-FI WITH ROUTER INTELLINET 524704.IT WORKS PERFECT BUT THE BIG PROBLEM IS THAT ONLY ONE DEVICE AT...
Your problem is with the 524704 device. This is NOT a router - it is a wireless access point. It is designed to be connected TO a DHCP router that can assign separate and unique IP addresses to each device that the Access point connects to. The way you are using this device will not work with more than one device since the unit is forced to use the fixed IP address from the wireless access point to the modem and only one device can use any specific IP address. You need to get a wireless ROUTER to achieve you goals.
Nov 03, 2013 | INTELLINET Computers & Internet
Hello i just purchased the wireless 300N access point and im unable to set a password. I have a mac i dont know if that matters but the ip address 192.168.2.1 is not popping up
Hi!
Try 192.168.1.1 if that is the default IP address as indicated in the box.
also, make sure you are indeed connected to the network. For simplicity's sake, connect a straight thru cable the the router's port number 1 to your PC. and set the configuration there.
Also, make sure the PC's ip address is set to DHCP.
Let me know if this helps out
Jan 13, 2011 | Intellinet Active Networking Intellinet...
Am asking for the default ip address for the router
You will get the default IP address for the router by following the instructions below.
1. Go to command prompt.
2. Type ipconfig and hit enter.
3. The address mentioned next to Default gateway is your Router IP address.
Note: Make sure that the router is connected to the computer using the Ethernet cable.
Nov 16, 2010 | Intellinet Active Networking Intellinet...
Router
maybe ip address change/.. check the ip of ur router
Aug 24, 2009 | Intellinet Active Networking Intellinet...
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cannot aquire IP address through my Desktop using Lynksis Wireless Router
sounds like you need to reenter the password/key
go to network connections and disconnect from it. then try to reconnect after the refreshes.
is it asking for a password/key?
Dec 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I can not connect to the local area connection.
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 justcheck the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
hope this will help you
Nov 26, 2008 | NetGear WGR614 Wireless Router
what you do is to reboot your desktop and everything will be fine or either unplug or disable and enable the status of the connestion. But the best way is to reboot the system. Good luck
Jun 29, 2008 | D-Link (DI-784) Wireless Router
Configure with utorrent
1.) To set up a static Ip address on your computer, click start, control panel, network and internet connections, network connections, right-click on local area network, click properties. In the window select tcp/ip, then click on the properties button.
Since your default gateway address is 192.168.2.1. Click on the selection titled 'Use the following ip address' Your Ip address should be 192.168.2.2, subnet mask 255.255.255.0, default gateway 192.168.2.1. Then in the next section click on the selection titled 'Use the following DNS server addresses' Preferred DNS would be 192.168.2.100 and alternate would be 192.168.2.200. click ok and you are done.
2.) As for the second problem, refer to the following link from the intellinet website. http://portforward.com/help/pfprogression.htm
Mar 05, 2008 | Intellinet Active Networking Intellinet...
Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246) Logo
95 people viewed this question
Top Intellinet Active Networking Computers & Internet Experts
Prashant M
Prashant M
John Hong
John Hong
Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
