Question about PNY 1GB microSD Memory Card
While formating or deleting files its showing ur card is write protected unable to this action, for what to do
Hello i am using 1gb pny micro sd card. while formating this card its showing you card is write protected, unable to format for this what to do reply me
  • 59 Answers
Yeah may be cause by virus and in some condation unlocker may fix this problem. Download latest version of Unlocker and do unlocking and then format the card.
Posted on Jun 25, 2009
  • 700 Answers
Could be virus. Scan it with your antivus. And may I ask what is your antivirus?
Posted on Apr 20, 2009
Remove write protection of my memory card
i have a my memory no four met of tha sho unable to fourmet write proteket
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
I have a 1GB corsair SD flash card with photos; only 75% deleted and I get a write protection message. Its used in Lumix DMC-FZ20 and it shows no photos on card but the PC shows 25% full. How do I...
just format it and if you want your data then,
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of datarecovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3,4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - selectextrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - selectdrive - Next - Create new or replace exiting configuration - Next - Hard drive - Next -Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Sep 16, 2011 | SanDisk 2GB microSD Memory Card
All accidentally deleted.
I would suggest you "NOT" to copy anymore files on your SD Card to prevent data loss or data corruption. Stop using it immediately.
Download an undelete program such as Undelete Plus. I think its a free download. and run the
program to recover your pictures. If you attempt to continue to use your SD Card you are at
higher risk of loosing your data.
Feb 04, 2011 | PNY 2GB microSD Memory Card
Write protected
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Jan 16, 2011 | PNY 2GB microSD Memory Card
My pny 2gb micro sd memory card is write-protected, i couldn't store or delete any files. what should i do? pls help me.
First check to see if it has a slide bar any where on the card itself to lock/unlock.
second download and install Sony EzRecover....
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Sony-EzRecover.shtml
and use it to format the card (which will erase all data).
If that doesn't work select Control Panel --> Administrative Tools--> "Disk Management. Select the micro SD drive and click Delete. Right-click on empty drive and select New Partition.
Jul 05, 2010 | PNY 2GB microSD Memory Card
Cant format my micro sd card
it means that the memory card's sector is damaged by a virus infection...try to delete the files while in the mobile and then format it..if it agains appear the same then you've to buy a new card only
Jul 05, 2009 | Transcend (589307) Media
Pny micro sd won't copy files
has the write protect been moved
Jun 26, 2009 | PNY 2GB microSD Memory Card
Micro sd card deleting problem
Dear,
You need not to think about that because such amount of space used by the Drive for its file system.
Regards,
Rakesh Kumar
Mar 31, 2009 | Kingston 1GB Secure Digital Memory Card
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
Kingston 1GB micro sd card
remove your sd card from unit...in sd card you can see very small slide switch..switch it off.
Feb 17, 2008 | Motorola Mobility RAZR V3m Cellular Phone
PNY 1GB microSD Memory Card Logo
248 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
