How to Install Scanner ColorPage HR8 Geniuns 64-bit Windows 8.1
First:
Getting Driver Genius for Windows Vista
http://download.geniusnet.com/2007/Scanner/HR8_V.zip
Microsoft reports no drivers from the manufacturer, to try luck with the driver of windows Vista, but does not explain how to make it work.
http://answers.microsoft.com/en-us/windows/forum/windows_8-hardware/drivers-for-genius-colorpage-hr8-scanner/3026b412-09db-48de-8665-6d1dda37b11d
After you download the driver, you have to run the "setup.exe" in support "Windows Vista" mode.
But before you do read the following explanation because you have to do something else before I install it, otherwise it does not work.
As I said, after trying I did not recognize the driver, I tried to take the driver manually
but windows saying that the driver was not digitally signed and you can't install if driver is not signed.
I Search the web such as disable that control and found a step in the url:
http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
After following the steps I could install the scanner driver and HR8 works correctly in Windows 8.1
LAST:
Now you can run the setup.exe in compatibility mode with Windows Vista, at the end makes restart the computer,
Now you got the scanner Genius ColorPage HR8 running on Windows 8.1
SOURCE: Genius and Vista
http://www.geniusnet.com.tw/geniusOnline/online.portal?_nfpb=true&supportPortlet_actionOverride=%2Fportlets%2FsupportArea%2Fdrivers%2FfindByModel&_windowLabel=supportPortlet&_pageLabel=supportPage&test=portlet-action
This
is the link to your driver support page. Simply enter your model and
operating system in the drop down menu and download your drivers and
install. If you need more help feel free to contact me.
Please don;t forget to rate me FixYa when this works for you. It would be greatly appreciated.
George
SOURCE: GENIUS COVERPAGE-HR8 Scanner
deseo instalar un scaner color page-vivid III v2 en windows XP, se puede? como?
SOURCE: Genius colorpage-HR8 driver for win
All you have to do is just click the link below so that you will be able to download the driver that you need. You can download it for free.
Just click_here so that you will be redirected to the exact site.
Thanks.
You may try uninstalling the existing drivers\software and install them in the Vista Compatibility Mode and check if it helps. To do so, follow these steps.
Go here: http://www.geniusnet.com/geniusOnl [...] let-action
Scroll down the page until you see the ColorPage Vivid 1200x - try selecting the Vista or XP driver package and seeing if you can force it to work.
That being said I do not believe any of the Genius brand scanners are on the Windows 7 Compatibility List. ( found here: http://www.microsoft.com/windows/c [...] s&v=Genius )
