4 year old rear projection type tv has white vibrating horisontal lines on bottom of screen
  • 1 more comment
  • peterbergen Apr 20, 2009
    tv is a old style (tube type? )Perhaps "rear projection" is wrong wording.ROWA did not make Plasmas or LCDs 4or5 years ago I don't think .Can u help me now?
    was suggested 2 me the " G2" adjustement could B out because of bump to it ,if so,can you inst ruct me how to fix it or do i need a tech?I haveDiploma in Music Production &many years of tinkering with amps,guitars,radios,T Vs etc.ie.can solder etc. Thanking you .PETER
  • peterbergen Apr 22, 2009
    Lines started on the bottom, the ones on the top also have red,blue&green lines.Can a tech fix this and approx how much should it cost? thanks 4 your time &effort,money will be on the way.Thanks Peter!
    Sergeant:
    Champion:
  • 219 Answers
Well being an engineer i think there is a technical fault in your TV so you certainly need a mechanic. Please call the service center. They will fix your problem immediately.
I hope it will help you.
Regards!
Sandy
Posted on Apr 22, 2009
  • 87 Answers
If these lines are thin you have a picture tube problem on crt board, if they start at the top you have a vertical blinking problem.
Posted on Apr 20, 2009
  • 19,396 Answers
That depends on the model.
On Toshiba this problem is typically related to hyperboard fault: Toshiba Rear Projection HDTV wavy lines
On Sony it is often a fault on digital board.
On other models it is often a fault with video chipset or in some case it can be a light engine faulty.
Ring the support phone number listed on the owner manual to get a quote on an eventual repair.
  • Ginko
    Ginko Apr 20, 2009
    If this is a CRT then you do not fix the problem by replacing a part. Traditional CRT TVs have many functions on same board, and on a CRT this is a vertical deflection problem, probably because a capacitor or a component on main board has blown or is malfunctioning. The job must be done by a technician.
Tv turns on ok,first displays black screen with 2 horisontal lines and some static at the top,than slowly from the top down i can see picture,after 5 min i can wacht tv but i have 2 lines -horisontal and...
Hi Marcin,
First of all, thank you for posting your question here at Fixya.
To diagnose accurately the exact caused of the symptoms, please let me know the Brand and model/chassis number of your unit. It is printed at the rear panel, manual and on the receipt. It will help to narrow down the symptoms and locate the availability of parts online.
Jdvillanueva
Jan 20, 2012 | Televison & Video
My tv blinks and no power on the screen. People tell me its the bulb and someone also told me it could be the ballast
In a projection TV there are three CRT high illuminessence tubes no ballasts or bulbs, do you have a dot in the middle of the screen??? do you have a white line (horisontal or vertical)??? is it realy a projection TV not LCD or PLASMA???? post the make and model if you want us to help!!
Sep 24, 2011 | Televison & Video
32 INCH ZENITH PICTURE IN PICTURE ABOUT 15 YEARS OLD.PICTURE DISAPPEARED AND ONLY HAVE A THIN WHITE LINE RUNNING ACROSS THE SCREEN.THE SOUND STILL WORKS FINE. IS IT WORTHWHILE GETTING IT REPAIRED ??
When CRT TV's show only a white/bright line horizonatlly It is a failure of the flyback Transformer. Not all that costly to repair. Your old TV will probably still be working when all the latest plasmas and rear projections have been laid to rest. Fancy junk TV's dont get any better programs than those old reliable ones
Please rate my help++++Thanks for using FRIXYA
Aug 04, 2010 | Televison & Video
My large screen projector type tv has a picture but there is groups of lined running across the screen from top to bottom. audio fine.
Sounds like hum bars if there white bars.Try disconnecting the ground outside at your cable hookups or sat etc.
Sep 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
LCD Sony TV - Skwiggly line
Hey there I think the problem is coming from your LCD chips not your bulb, the bulb has nothing to do with the color or skwiggly lines it just shoots out white light,your LCD chips are burnt and the problem will not stop by changing your light bulb you need to replace the OPTICAL BLOCK the skwiggly line will just get worst with time
hope this helps
please rate this solution !!!!
Oct 12, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
White lines
i have same problem, i have 55 projection tv mitsubishi, i get those white lines. how can i fix the problem.?
thank you.
Mar 27, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
