Question about Philips AJ3010 Clock Radio
My clock AJ 3010 clock radio gives off an electronic sound every 10 to 20 minutes. It's like a warning sound you get from a smoke alarm when a battery is running low. I've tried replacing the batteries but the annoying little sound persists. Please help?
  • johnkelly110 Apr 20, 2009
    My problem is with a Phillips AJ 3010 Clock Radio! Absolutely nothing to do with with pc settings!
If you want to turn off all system beeps (like the ones that go through your computers' internal speaker ):
  1. Go to Start-->Run-->Type Regedit.
  2. Go to HKEY_CURRENT_USER\Control Panel\Sound
  3. Edit the key Beep and give it a value of No
This will help you to turn off system beeps.
Posted on Apr 20, 2009
How do set the wake up alarm on am/fm digital clock radio model ONB14AV201
1. With the unit in CLOCK mode, press and hold the ALM1/VOL+ or ALM2/VOL? button. The ALARM time will begin to flash on the LED display.
2. Press the ?/HR button to adjust the alarm hour.
3. Press the ?/MIN button to adjust the alarm minute.
4. When the correct time is selected, press the ALM1/VOL+ or ALM2/VOL? button to confirm.
5. Press the ALM1/VOL+ or ALM2/VOL? button to select the ALARM sound mode - buzzer or currently set radio station. The alarm buzzer or radio indicator will light up.
Jan 21, 2015 | Audio Players & Recorders
I need the user manual for an alarm clock called clok. I can't set the time or radio stations
These steps will only work while your unit is OFF. The power button is located at the top left face of the unit.
How to set time?
1. With the unit OFF, press and hold down the Clock/Display/Play/Pause button for at least 5 seconds.
2. While still holding the Clock/Display/Play/Pause button, press the Hour, and then the Minute button to adjust the hour and the minute on the time.
3. After selecting the correct hour and minute time, release the Clock/Display/Play/Pause button to set the clock.
How to set the alarm?
1. With the unit OFF, press and hold down the AL1 or AL2 button for at least 5 seconds. (an alarm icon will flash on the lcd display)
2. While still holding down the AL1 or AL2 button, press the Hour and the Minute button o adjust the hour and minute on the alarm time.
3. After selecting the correct time for alarm, release the AL1 or AL2 button to set the Alarm time.
4. Press the AL1 or AL2 button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio or a docked iPod.
Apr 17, 2011 | Audio Players & Recorders
How do I set the alarms -- I've lost my manual
The manual:
http://www.retrevo.com/support/Lenoxx-CDR-190-Clock-Radios-manual/id/22975ci174/t/2/
Hold the Time Button down,
and press the Hour Button,
until the right hour time shows
in the display.
and press the Minute Button
until the right minute time
shows in the display.
Jan 18, 2011 | Lenoxx Electronics CDR-190 Clock Radio
How do I set the clock and the alarm on my lenoxx radio/ipod dock device?
http://www.retrevo.com/search?q=Lenoxx+Electronics+CDR-190
Page 1 and 8
Basically, hold the time button and adjust the hour and minute; hold the alarm button and adjust the hour and minute using the buttons.
Jan 15, 2011 | Lenoxx Electronics CDR-190 Clock Radio
My alarm clock does not distinguish between AM and PM. it simply does not turn on the sign for either, so i cant tell if my alarms are set for am or pm...kind of important.
Sounds like a display problem where the indicator isn't working. This might be a bad connection or it could be the display itself or the driving electronics. In any case, it would probably cost you more than the clock radio's worth to have it repaired (assuming you find someone who'd take it for repair in the first place!).
Here's a "solution", though. Set your alarm for a time only a couple of minutes later than the current time and wait around. Depending on whether or not the alarm sounds, you'll know if it's set for AM or PM. At least you'll be able to keep using it until you decide to replace it.
Oct 06, 2010 | Memorex iWake MI4004 Clock Radio
Hi . My clock radio clock continuously displays
Likely a bad backup battery inside the clock, or a capacitor that is leaking a charge.
Nov 17, 2017 | Lenoxx Electronics CDR-190 Clock Radio
Unable to set the alarm
To Set the alarm time: Press and hold the ALARM button down, and then press the hour/minute buttons to obtain desired time (Note the PM indicator on the screen for PM times)
To Enable the alarm: Move the sliding switch to AUTO or ALARM (Auto is for radio wake and Alarm is for beeping noise) *remember to turn up the volume knob if using AUTO (radio) setting.
Dec 04, 2008 | Lenoxx Electronics Clock Radio With CD...
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Sep 14, 2007 | Sharper Image SI686 Clock Radio
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
Philips AJ3010 Clock Radio Logo
580 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
