Question about Microsoft Age of Empires: Gold Edition for Windows
Need Help with "Could not initialize graphic system. Make sure your Graphics card and driver are compatible with direct draw."
    Problem Solver:
  • 9 Answers
What is your computer xp or lower?
because this may mean that your graphic card can be to old.
Posted on May 22, 2009
Will a DDR3 graphic card work as it should work on a DDR2 motherboard or ram
Add more RAM
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system.
You should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible.
computer users often get confused when assembling or upgrading their first computer. While the most common error is made when distinguishing system memory, RAM, from hard drive space, gaming computers have an extra wrinkle to worry about.
Graphics cards use memory separately from the system memory mounted on the motherboard. Some graphics cards use the more typical DDR standard, though it's permanently attached to the graphics card circuitboard, while others use the new GDDR standard.
For the most part, the internals of the graphics card aren't relevant to the rest of the computer it's all about the connection slot.What Is DDR Memory?
DDR, or "Double Data Rate," is the standardized random access memory format for most desktop and laptop computers.
DDR RAM comes in different generational standards: DDR, DDR2, DDR3 and the newer DDR4.
RAM chips, known as DIMMs, come in only one format, as do the DIMM slots on motherboards, so a DDR3-compatible motherboard memory slot can accept only DDR3 RAM DIMMs RAM that uses an earlier or later standard is incompatible.
GDDR Memory and Graphics Cards
Modern graphics cards use a modified memory standard called GDDR, short for Graphics Double Data Rate. While similar, GDDR and DDR memory is not the same:
Most importantly, GDDR memory is integrated into the graphics card and cannot be removed. Some older graphics cards use DDR, DDR2 and DDR3 memory, but this is also integrated into the card.
Graphics cards of varying power come with different kinds of RAM as of the date of publication, most cards feature GDDR4 or GDDR5 memory
Graphics Card Motherboard Connections
Discrete desktop graphics cards are mounted inside a computer case and plugged directly into the motherboard.
Three standard connections are used for graphics cards: PCI-Express (the most common and powerful), PCI and AGP.
It is this connection that determines how much data can be shared between the graphics card and the other system components, such as the CPU, the system RAM and the hard drive.
The expansion slot standard is the primary function for determining whether or not a graphics card is compatible with any given computer:
If your motherboard has a PCI-E slot, it's compatible, if not ideally so, with all PCI-E graphics cards.
Graphics Card Memory and System Memory Compatability
Memory is an important part of game performance, but graphics memory and system memory are two different things.
For better performance, it's best to have as much graphics memory AND system memory as possible, but the different standards used by the graphics card and the motherboard are largely irrelevant.
As long as the graphics card uses the correct expansion slot standard, it will work with the corresponding motherboard, regardless of its DDR version.
Mar 10, 2014 | IBM Lenovo ThinkCentre M55e PC Desktop
Video controller(vga compatible) could not be instaled at my window xp
if you have an older system (2000-2004 production) and the graphic card is AGP type, you may need to first install the AGP port drivers and only then go to installing the graphics card.
Also, make sure you have the correct drivers for your graphics card.
Check your PC's documentation to find out the AGP model, and check your graphics card details and download the latest drivers that match your operating system.
If this post was useful and informative please vote for it with a Thumb Up. Thank you.
Jan 19, 2011 | Computers & Internet
What video card are compatable with SR1620NX ? The graphics card is not working right anymore and I need a compatable video card.
A PCI Express graphics card.
Doesn't matter if the PCI Express graphics card uses the PCI Express 2.0 technology, or the PCI Express 2.1 technology.
The PCI Express graphics card, will insert into the PCI Express x16 expansion slot on the motherboard.
Supporting data;
1) View of the motherboard in an illustration,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1127351
Scroll down the page to view the motherboard illustration.
A) Looking at the illustration, view the BATT. (CMOS Battery)
To the left of the CMOS Battery (BATT) are three white PCI slots.
Above them is a longer expansion slot. This is the PCI Express x16 slot.
Above it is marked > PCIX16X1 (PCI x16 times 1 slot)
NOTE* When installing the PCI Express graphics card, lift up gently on the Lock 'handle'.
It looks as though you should push down on it, but you need to lift up on it instead.
Also go above the motherboard illustration, and read to the right of the heading > Internal Connectors
In the list you will see > One PCI Express x16 graphics slot.
WHEN installing a graphics card, ALWAYS install the software from the CD disk provided, First!
Computer on, and Windows running, insert the graphics card's Installation disk, (CD) into the optical drive tray.
Install the software by following the directions.
THEN shut the computer down normally, and unplug the computer from power.
OBSERVE Anti-Static Precautions.
Install the graphics card.
Close the computer case, and plug the monitor into the graphics card.
Turn the computer on.
When you install a device (Such as a graphics card for example), Windows will try to find compatible drivers.
IF, THE driver is not installed First, Windows will match up one of it's thousands of generic drivers.
This = No.
You want THE driver installed first, so that Windows will find it, and Not try to match on of it's generic drivers.
NOTE 2*
It DOESN'T MATTER what graphics ram memory the graphics card has.
The graphics card's Processor and Ram Memory operates independent of the system resources.
Example:
The computer uses DDR Sdram ram memory.
The graphics card uses GDDR5 graphics ram memory.
It will work just fine.
NOTE 3*
It does NOT matter if your computer uses the PCI Express 1.1 technology, and the graphics card uses the PCI Express 2.0, or 2.1 technology.
PCI Express 2.0, and 2.1 technology is Backward Compatible with PCI Express 1.1 technology.
Will you get the full capability of the PCI Express 2.0, or 2.1 graphics card?
NO
Will you notice?
NO
What you need to look at it, is how much power will the graphics card use. Look at the system requirements for the graphics card, and be sure your Power Supply has enough power for that graphics card.
Also, IF, the graphics card requires additional power cables from the Power Supply, make sure your Power Supply has the required power cable, or power cables.
IF the Power Supply does not, use a power adapter cable.
NOTE 4*
Graphics card manufacturer's base the power needed for the graphics card, Not just on the graphics card itself, but on an entire computer system, AND the graphics card.
The graphics card manufacturers use a test computer system, that is a powerful computer system.
Gamer motherboard, Dual Core, or Quad Core processor, 4GB of ram memory, and at least two harddrives, and two optical drives, PLUS the graphics card in question.
This complete computer system uses a LOT more power than just the graphics card by itself.
There isn't a single graphics card out there, that uses more than 150 Watts by itself.
Recommendations for a graphics card that is compatible, with a Compaq Presario SR1620nx desktop computer?
Budget to medium:
Good enough to watch videos, older games, and some newer games.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675217&CatId=3670
Medium:
Higher level games, and large screen monitors,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6642574&CatId=3669
For questions post in a Comment.
Regards,
joecoolvette
Dec 18, 2010 | HP Compaq Presario SR1620NX...
Game not working
i installed the game ... did everything in read me doc ... but it's given an error saying , graphic serviecs faild to initialize .
Jul 23, 2009 | Philips Sonic Edge 5.1 PSC605 Sound Card
The graphic organizer won't work it says i need DirectX 9.0c
First thing you do is check your system requierments,(should be located on the back of your CD case, or somewhere in your manuel, probebly under the title "System Requirments") it will probebly say something like "complete Direct-X compatible graphics adapter requiered". You then go to Start Menu-->Run (type in "dxdiag" (without quotes)) and see if you have the correct graphics card, and or graphics adapter.
If you do have the correct system requierments repost your problem saying you have the correct system requierments but you still get the following message: "Failed to find any Directx9.0 compatible graphics adapters in this system! Please make sure you have a DirectX 9.0c compatible graphics adapter and have installed the latest drivers provide by the manufactuer. The application will now terminate."
If you do not have the correct system requierments, you cannot play the game on that computer.
Hope this helps.
Levi_xx
Jul 10, 2009 | EA - Electronic Arts The Sims Double...
Age of empire doen't work in my nvidia mx4000 graphics card.following message error comes"failure to initialize graphics system.enable your driver and compatible direct draw
which version of age of empires 1 or 2 or 3 check in the system requirements of the game. you can see ur graphics card given there if supported
Apr 18, 2009 | Jaton Graphics Card - nVIDIA GeForceMX4000...
Direct X compatibility issue with new graphics card
Hi tom2badcat, the SIMS game is very picky when it comes to graphics cards. If you look on the SIMS box you'll find their recomended graphics card list. The video card you bought is a low end 8x AGP card. You can try downloading & installing directx 9.0c from microsoft. Click on this link;
http://www.microsoft.com/downloads/details.aspx?familyid=9226a611-62fe-4f61-aba1-914185249413&displaylang=en
If directx 9.0c still fails to install the graphics card is at fault & you should return it. Listed below is a link. The link provides a couple 8x AGP graphics cards that will run both directx 9.0c & the SIMS expansion pack 2. (The graphic cards shown all use faster memory).
XFX cards carry a lifetime warranty. (No# Choice)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1776106&CatId=318
Below is a whole list of 8x AGP cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&name=AGP&
Brief Description:
November 2008
The Microsoft DirectX® End-User Runtime provides updates to 9.0c and previous versions of DirectX — the core Windows® technology that drives high-speed multimedia and games on the PC.
Jan 03, 2009 | Pine Technology 3D Phantom Xabre 200, (32...
try reinstalling dx9c by either going into the games disk folder and finding the installation or getting a diffrent game with dx9c and installing it out of the folder
Jan 03, 2009 | Sis Xabre 400 Ultra, (128 MB) Graphic Card
Installed Call of Duty World at War,Cliked on Solo play but screen goes back to desktop. I have updated my graphics driver. My system is a Dell XPS 710 With a Radion X1950 Cross Fire Graphics card,Quid...
What are the Direct X recommendations for the game? Is your direct X up to date.?
You can check if your graphics card is compatible with 3D graphics by going to Start>run (just on the right below search), and type in dxdiag,
This will bring up your direct X diagnosis program and enable you to run some checks.
Check to see if 3D graphics Accelleration is enabled and then run the video and sound checks to make sure that you are having no problems.
Nov 17, 2008 | Computers & Internet
Graphics Card is not supporting Direct Draw
ensure your mainboard is capable of 8X AGP speed. also try to re-install video drivers.
Aug 18, 2007 | Nvidia WinFast GeForce4 MX4000 128MB DDR...
Microsoft Age of Empires: Gold Edition for Windows Logo
155 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
