HARD DISK NOT FOUND MESSAGE ON SCREEN
While working in laptop, suddenly screen went blank & tried to restart it, but displayed message as hard disk not found, in bios it is showing the presence but even loading windows xp setup showing the message as 'no hard disk is found'... service centre techs told that there may be mother board problem...please assist me get rid off this problem. Thanks, madhu
    Scholar:
  • 69 Answers
There might be few reasons for this.
The worst is that your Motherboard/HDD is broken, but I am almost sure that this is NOT the case. Motherboards and HDDs do not burn just like that !
The good thing is that you can 'see' your HDD in BIOS, which means it is not dead!
There can also be a wrong BIOS settings for the HDD controller. Check BIOS settings for your HDD-SATA controller. Somehow maybe your BIOS lost/changed HDD settings.
The problem is that I am not sure you can check your HDD on another computer. If you can do that, then it is the best chance to determine if something is wrong with your HDD, Also there (on another computer) you can more easy use some HDD test and repair software. Also, that way you can easy make backup of your important files.
Bott from WINXP BOOT disk and try recovery console (chkdsk/p at command prompt)
Try to download Hiren's Boot CD(http://www.hiren.info/pages/bootcd).
Regards
Posted on Apr 20, 2009
Operating system not found
there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
Apr 10, 2013 | Samsung N150 Notebook
I tried to restore my sister laptop..but i got a message saying restore failed..so when i tried to restart the computer...i just got a black screen with the message NTLDR IS MISSING...Press ctrl+alt+Del...
Hi there, I did a bit of research on this for you and this is what I found:
First off, there are numerous causes which could be giving you this message. Odds are it's because reformatting wasn't completed properly, which means something on your computer hasn't been set up properly.
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and/or NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32. New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS.
Jan 06, 2011 | Acer Pink 101 Aspire One AOD2602571...
My acer m5640 with vista all the sudden crashed got the blue sceen so i renistalled windows when i did in the proccess it shut off then when i went to restart it the screen was blank it came up no signal...
Remove the CMOS battery and remove hard disk connection from the motherboard. Then restart ur system. It will give u the msg no boot device found. Now reinsert the CMOS and hard disk connection.
Apr 27, 2010 | Acer Aspire m5640 PC Desktop
Problem with booting-up on HP Pavilion dv9334us laptop
1.there is problem in screen fl inverter replace it screen will on
2.format and reload the windows
Mar 26, 2009 | Computers & Internet
My HP pavilion dv2713TU laptop does not start, blank screen.
usko land me dal kar chuus fhir randi baja sale banh ke loade,chut age se chut chatio
Mar 14, 2009 | HP Pavilion dv6000z Notebook
This message means that the hard disk was not detected, this is due to either the BIOS setting was changed or the hard disk has failed.
Try booting up with a DOS disk and run FDISK, and see if it detects the hard drive, if possible run a diag test program.
Nov 22, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq desktop pc not detecting any hard disk
it shows, you lost your hard disk, if it is in warrenty claim it first otherwise consult any technician
Oct 23, 2008 | Computers & Internet
Hard disk not found?!
i thik u have to format the hard disk and try it again. or may be u have change to the security settings.
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
SUDDEN SHUTDOWN
I am Vikram Kumar Thumu from India-Hyderabad. I would like to provide you my suggestions on this issue for you...
Well, this issue could happen only due to below three reasons....
1. If the Hard Disk Drive is bad.
2. If RAM card is not working properly.
3. If there is an error with Operating system...
However, to isolate and to resolve the issue I recommend you to perform below solutions and try out. I hope that this should resolve the issue for you.
Solution 1: BIOS UPDATE OR BIOS FLASH
Note**--- THIS BIOS UPDATE IS APPLICABLE IF YOU ARE USING WINDOWS XP.
NOTE**-- If you are ready to perform BIOS update, please connect the Notebook with Ac Adapter and make sure that Battery is also installed for Notebook.
Please open below link in the new Internet Explorer web page...
The web page titles as " WinFlash Utility for HP Notebook System BIOS; Windows-Based"
Link is:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-39816-1&lc=en&cc=us&dlc=en&product=435618&os=228&lang=en
Once if you open the web page, please click on the option " Download Only" and then try to save the download file on Desktop and run the file after download is completed.
This should successfully install the BIOS Update. However, if the issue still persists then please perform next solution
Solution 2:
In this solution we will check the functionality of Hard Disk Drive...
Please restart the Notebook, while it tries to boot up please press F10 key, this should get into BIOS screen or ( SETUP UTILITY ) screen.
In the BIOS screen please locate to the Tools or Advanced Menu, and then select the option HARD DRIVE SELF TEST. and go ahead with testing the HARD DRIVE SELF TEST.
Once if test is completed, it reports a message of the status on Condition of Hard Disk Drive. If you receive error message then it confirms that this is an issue with hard Disk Drive. then you need to replace the Hard Disk Drive for your Notebook.
Else if it reports success, then it confirms that Hard Drive Drive is perfectly alright..
Then only possibility that is left is " Error with Operating system"..
if you found that it is an issue with Operating System then please go ahead with reinstall of the Operating System for your Notebook PC.
This should resolve the issue for you...
If you need any further assistance on this issue, you can mail me at thumuvikram@rediffmail.com , I'll be glad to help you further on this issue.
Bye..
Nov 08, 2007 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
